EAGLE User Support (English) Eagle upgrade costs
  • Replies 61 replies
  • Answers 2 answers
  • Subscribers 189 subscribers
  • Views 7939 views
Eagle upgrade costs
stevekale
stevekale over 9 years ago
I use the Make version of Eagle - something I may now come to regret versus starting with an open source package from the beginning.
I am not using the software for commercial use, rather for DIY audio electronics.  But I now need a board area greater than 16cm x 10cm. For my current project, I need about 20cm of length.  There appears to be nothing between Make and Ultimate for commercial use (with or without Autorouter which I do not use).
I wanted to check the upgrade cost yet when I enter my user license online to get an instant quote for upgrading  I merely get the  cost of buying a version from scratch - including an option to buy what I already have for what I have already paid.  Rather daft.
How to get the correct upgrade costs?  And am I the only one that would like to see a non-commercial offering with a larger board area at a more sensible price? (I will never need 4m x 4m board area, nor more than 4 signal layers.)  This is the sort of thing which forces people to learn KiCad or another competitor product.
    autodeskguest over 9 years ago in reply to stevekale +2 suggested
    On 1/10/2017 7:47 AM, Steve Kale wrote: Hi. Thanks I will email them. It would be good if mattbergren can comment as the leap to Ultimate for DIY use is preventatively expensive. Regretfully I'm about…
  • e14candies
    e14candies over 9 years ago +1
    You can use some tricks and special editing commands to make a larger board if you really need to, however, it is much easier to upgrade Eagle to the size you need. Hopefully the new pricing/versions will…
  • rachaelp
    rachaelp over 9 years ago +1
    Looking on the cadsoft.io website this morning there is now a big splash screen saying the biggest release of EAGLE to date is coming soon. Judging by the snippets shown on that screen I have to say I…
  • stevekale
    0 stevekale over 9 years ago in reply to autodeskguest
    It's $119 if you are in the UK.  And that excludes VAT.
    Does the 160cm^2 size allow a board of, for example, 5cm x 30cm or is dimensionally restricted?
    (Having seen how easy it is to migrate to KiCad I'm not sure even this is worth the money.)
    0 autodeskguest over 9 years ago in reply to stevekale
    https://www.element14.com/community/message/215846
    Hi Steve,
    I hope you're doing well. The area limitation is based on area so 5cm x
    30cm would work just fine. Under the previous licensing mechanism it was
    restricted to a fixed 16cm x 10cm board.
    Hope this helps.
    Best Regards,
    We have a new forum here <http://forums.autodesk.com>
    0 autodeskguest over 9 years ago in reply to autodeskguest
    Jorge Garcia wrote:
    I hope you're doing well. The area limitation is based on area so 5cm x 30cm
    would work just fine. Under the previous licensing mechanism it was restricted
    Hope this helps.
    Yes,
    Back to my comment:  Why don't negative coordinates work?
    Hope this helps.
    Yes,
    Hope this helps.
    Yes,
    Hi Antti,
    EAGLE still enforces size limited by requiring that you stay in the
    positive x and y axes.
    You can use a relative origin to define a center for boards where you
    would want the center of the board to be, you can then reference all of
    the coordinates to that relative origin.
    That's how it works right now.
    Best Regards,
    Jorge Garcia
    Jorge Garcia wrote:
    EAGLE still enforces size limited by requiring that you stay in the positive x
    and y axes.
    You can use a relative origin to define a center for boards where you would want
    the center of the board to be, you can then reference all of the coordinates to
    It doesn't really help as Info still gives just absolute coordinates and not
    relative coordinates!  And I cannot place a component with Info dialog with
    relative coordinates, or is it possible?
    It would be really easy to fix:
    Instead of
    if ((max_x*2 + max_y*2) > limit)
         goto bummer;
    just code:
    if (((max_x-min_x)*2 + (max_y-min_y)*2) > limit)
         goto bummer;
    Current limitation is just lazy coding.
    Get this fixed, please.  As it is now, the feature presentation "Includes 99
    schematic sheets, 4 signal layers, and 160 cm2 board area" is misleading.
    On 2/15/2017 6:10 PM, Antti Louko wrote:
    and y axes.
    Instead of
         goto bummer;
    just code:
         goto bummer;
    Hello Antti,
    Moving components through the info dialog can get old kind of quick. You
    can't specify relative coordinates in the Info dialog, however you can
    specify relative locations easily following this procedure:
    1. Left-Click Move icon
    2. Left-Click on part, it will now be floating on your mouse cursor.
    3. Type (R x-loc y-loc) and then hit enter. Where x-loc and y-loc are
    the coordinates of the location you want referenced to the relative origin.
    Hope this helps,
    Jorge Garcia
    Jorge Garcia wrote:
    Moving components through the info dialog can get old kind of quick. You can't
    specify relative coordinates in the Info dialog, however you can specify
    3. Type (R x-loc y-loc) and then hit enter. Where x-loc and y-loc are the
    Hope this helps,
    Using Info dialog for moving relates usually to situations where one wants to
    try different values for coordinates, angle and so on, using "Apply" to keep the
    dialog open.  The method you present, which is useful for some other situations,
    doesn't really help here.
    And still, I cannot get the relative coordinates for easy copy for pasting it
    elsewhere.
    So please fix this.
    I paid for one month for testing Eagle 8 and it is expiring soon.  There is
    little motivation to pay more.
    elsewhere.
    So please fix this.
    Hi Antti,
    Thanks for your feedback, what you are asking for a is a new feature and
    not a fix.
    The INFO dialog always works with the absolute origin. I'll create an
    enhancement request so that the info dialog can reference the relative
    origin.
    Best Regards,
    Jorge Garcia
    On Mon, 13 Feb 2017 10:03:34 +0100, Joern Paschedag
    <jpaschedag@t-online.de> wrote:
    AD has not changed electronic components (and can not do it) so that
    only eagle v.8 can handle it.
    Sure they have.  Try opening a V7 drawing in an earlier version.  You
    can't.  That's why I have to keep V4 and up installed on my machine.
    The REAL problem comes when you find a project on the net or in a
    magazine that you'd like to use some part of.  Saves reinventing the
    wheel.  The project is usually posted in the current Eagle format.  So
    you have to have that version installed.  And Eagle doesn't let one
    back-port to an earlier version so if you want to cut a piece out of
    the project schematic and paste it in yours, you're SOL.
    Unfortunately owners of acquired smaller companies try to adapt them to
    their own scheme and forget the old word "Never change a running system".
    SOP for AutoDesk.  Perhaps some of you CadSoft people can ask around
    and find out what AutoDesk did to MoldFlow.   Hint: It isn't pretty!!!
    I shall, at least for some time, continue with my perpetual license,
    because during the years working with eagle I have developed a lot of
    libraries, imho an investment of time that would be lost.
    AD stands for their opinion, I  stand for mine.
    Goodbye eagle.
    My approach is to convert us over to KiCAD now and convert Eagle
    library entries only as they are needed.
    John DeArmond
    http://www.neon-john.com
    http://www.tnduction.com
    Tellico Plains, Occupied TN
    See website for email address
