EAGLE User Support (English) Eagle upgrade costs
  • Replies 61 replies
  • Answers 2 answers
  • Subscribers 196 subscribers
  • Views 9226 views
Eagle upgrade costs
stevekale
stevekale over 9 years ago
I use the Make version of Eagle - something I may now come to regret versus starting with an open source package from the beginning.
I am not using the software for commercial use, rather for DIY audio electronics.  But I now need a board area greater than 16cm x 10cm. For my current project, I need about 20cm of length.  There appears to be nothing between Make and Ultimate for commercial use (with or without Autorouter which I do not use).
I wanted to check the upgrade cost yet when I enter my user license online to get an instant quote for upgrading  I merely get the  cost of buying a version from scratch - including an option to buy what I already have for what I have already paid.  Rather daft.
How to get the correct upgrade costs?  And am I the only one that would like to see a non-commercial offering with a larger board area at a more sensible price? (I will never need 4m x 4m board area, nor more than 4 signal layers.)  This is the sort of thing which forces people to learn KiCad or another competitor product.
    0 autodeskguest over 9 years ago in reply to autodeskguest
    On 03/23/2017 02:45 PM, warrenbrayshaw wrote:
    On 24/03/2017 6:40 a.m., Don Haselwood wrote:
    John,
    I'm trying to get my eagle version 4.13 running on Ubuntu 16.04 LTS on
    a 64b machine, but the window area with the schematic and board layout
    is blank, no matter what I do.  I did get the transparency issue
    resolved, but the inability to make anything appear in the work area
    window remains.  It appears to be a Ubuntu 16 issue as I do have an
    older machine running Ubuntu 14.04 and it is OK..  I wondered if you
    had that problem, and if so, what you did to fix it.   (I've tried all
    sorts of things I've found online having to do with the 32bit libs,
    but no success.)
    As far as upgrade goes--my paid version 4.13 is quite satisfactory for
    what I do (retired, hobbyist).  It produces what I want for the boards
    and the notion of no additional cost for eagle upgrades just doesn't
    offer anything.  (In my experience, software upgrades offer the hope
    of something better, but instead replace of old, known problems with
    new problems yet to be discovered.)  Kicad is attractive, but I can
    hit the right keys with my eagle 4.1 automatically without
    looking/thinking so continuing with eagle 4.1 (and not a later
    version!) is quite desirable.
    https://www.element14.com/community/message/219285
    Hi Don
    Start by downloading the last point version of Eagle V4 (4.16r2) as your
    licence qualifies you for it.
    ftp://ftp.cadsoft.de/eagle/program/4.16r2/
    Then, I suspect there are some missing linux drivers that you will need
    to locate. This has been a problem from time to time.
    Others may be able to give you an exact answer.
    Failing that search the forum. I suspect E14 is not the place to do
    that. Search eagle central but let google do the heavy lifting when you
    have multpile works you wish to search for. e.g
    site:eaglecentral.ca  "linux drivers" "missing"
    HTH
    Warren
    I am running on a recent version of linux mint with xfce. Also on 4.x. I
    found the windows were transparent. I had to change the desktop setting
    (window mangager) to not use compositing. This fixed the transparent
    windows.
    With compositing enabled.
    Paul R. via newsgroup
    0 autodeskguest over 9 years ago in reply to deh6
    John,
    I'm trying to get my eagle version 4.13 running on Ubuntu 16.04 LTS on a 64b machine, but the window area with the schematic and board layout is blank, no matter what I do.  I did get the transparency issue resolved, but the inability to make anything appear in the work area window remains.  It appears to be a Ubuntu 16 issue as I do have an older machine running Ubuntu 14.04 and it is OK..  I wondered if you had that problem, and if so, what you did to fix it.   (I've tried all sorts of things I've found online having to do with the 32bit libs, but no success.)
    As far as upgrade goes--my paid version 4.13 is quite satisfactory for what I do (retired, hobbyist).  It produces what I want for the boards and the notion of no additional cost for eagle upgrades just doesn't offer anything.  (In my experience, software upgrades offer the hope of something better, but instead replace of old, known problems with new problems yet to be discovered.)  Kicad is attractive, but I can hit the right keys with my eagle 4.1 automatically without looking/thinking so continuing with eagle 4.1 (and not a later version!) is quite desirable.
    Hi Don
    HTH
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
    John,
    Hi Don
    HTH
    Warren
    Thunderbird!
    support forums.
  • deh6
    0 deh6 over 9 years ago in reply to autodeskguest
    John,
  • levafreidin
    0 levafreidin over 9 years ago in reply to kikoun
    Thank you!
    I have V7.7, it works under Win7 and Win10, so I will follow you:
    I will stay with EAGLE till it works, after that - switch to KiCAD.
          Thanks again.
                       Sincerely yours,
                                  Lev Freidin.
  • dukepro
    0 dukepro over 9 years ago in reply to rachaelp
    On 02/25/2017 06:04 AM, rachaelp wrote:
    Guillaume barrey wrote:
    So in my humble opinion, it's urgent to do nothing drastic.
    I agree with this totally. v7 works well and can still be a good tool for many years to come.
    Anyway, I do not have any trust in cadsoft/Autodesk now, and even they go back to the previous licensing scheme, I think I will not pay any Euro or whatever to them.
    If Autodesk corporate have a change in policy and start to allow other licensing types again then things might change for the better and if a really excellent newer version of EAGLE came out that you could get a perpetual license for then you might find yourself in a situation where upgrading to it was the smart business decision and then you too would have to do a complete u-turn and eat a slice of humble pie image
    Good morning, Rachael,
    Humble pie?  Well... not really.  If one could get a perpetual license,
    then it would not be a u-turn.  It would be a return to terms that have
    been acceptable for decades.
    If there's one thing that my attorneys have drilled into me over the
    course of time is that everything is negotiable - everything.  I
    occasionally joke that everything I own is for sale for the right price,
    except my wife and my dogs - and on certain days we can talk about the
    wife.  On a more realistic note, I'm sure that if one were to walk into
    Autodesk HQ and offer $500,000 in exchange for a perpetual license with
    unlimited updates, Autodesk would find a way to do it.  Perhaps that
    wouldn't be enough... Perhaps a new personal jet for the Board would do
    it.  I'm not talking about a bribe; instead I'm referring to an
    equitable exchange of value.  I provide this, and in exchange they
    provide that.
    Autodesk might make a counter offer.  It's all negotiable.
    Much of the license chatter stems from the unilateral action Autodesk
    took in changing to a subscription based license.  In doing so, they did
    not break any contracts.  Nobody was legally bound to acquire a
    subscription.   The existing agreements applied strictly to the major
    version under which it was issued.  I say that the subscription action
    was "unilateral" - more precisely, it was a different way of doing
    business starting with V8, and is entirely within their prerogative to
    do so.
    Now, can anyone honestly claim that they truly didn't think this would
    happen, even after knowing that nearly every other product offered by
    Autodesk is on a subscription basis, and even despite what Matt claimed
    back in July?  The minute I learned that Autodesk bought Eagle, I knew
    that it was only a matter of time before they wrapped their subscription
    business model around it.
    Nonetheless, Autodesk has a real public relations problem.  They
    unexpectedly made the announcement with the introduction of a new major
    revision.  They didn't offer any transition path for existing
    customers.  They just made a press release.  Boom!  It's out there.  I'm
    sure it's not unlike that which they faced when moving other products to
    a subscription, and thus it is nothing new to them.  The noise will pass...
    I really expect that soon Eagle will no longer be called "Eagle".  I
    expect Autodesk will rebranded it.   Rebranding is most likely already
    in the works.  Quite frankly, I'm surprised it didn't happen with V8 -
    that would have been the better PR move.
    As for a reasonable transition, perhaps a perpetual license should have
    been made available exclusively to existing customers to ease the
    transition.  Something like: for the first year, offer existing
    customers of 4 years or more (again, negotiable) perpetual licenses.
    That would cover customers that have a significant investment in
    designs.  While Autodesk would miss the subscription revenue from this
    customer set, they would have more than made up for it with PR.
    As it is now, they have high-end engineers around the world that have
    used Eagle for a long time (some for decades), that really don't have
    anything positive to say.
    Rachael, Like you, I'm sticking with the perpetual license for v7.  When
    I face a project that exceeds its capability, I will have to consider a
    move to a different ECAD solution.
    Best regards,
        - Chuck
    0 autodeskguest over 9 years ago in reply to rachaelp
    On Sat, 25 Feb 2017 13:46:15 +0000, Rachael <rachael@rachellie.co.uk>
    wrote:
    You can choose to deal with the changes in EAGLE licensing how you see fit
    for your situation, but you are not in any position to brand other people
    stupid because they don't necessarily agree with your point of view. Many
    perhaps don't like it but equally don't want to throw away years of
    experience and investment in their setup, libraries etc. Please have
    respect for the opinions of others.
    I'm too polite to use the word "stupid" but I think that people who
    rely on an AutoDesk product that AutoDesk has bought are using poor
    judgement.  AutoDesk is famous for buying up little companies and if
    they don't "make the numbers", killing them off after sucking out
    their guts.
    With the mass migration away from Eagle that this rental scheme is
    causing, there is no way I'm going to trust Eagle to make the numbers
    and be around for the long haul.  I have to have something that both I
    and my customers can rely on.
    John DeArmond
    http://www.neon-john.com
    http://www.tnduction.com
    Tellico Plains, Occupied TN
    See website for email address
    On Fri, 24 Feb 2017 16:20:54 +0000 (UTC), Uwe Bonnes
    <bon@hertz.ikp.physik.tu-darmstadt.de> wrote:
    levafreidin <noreply-59652@element14.com> wrote:
    Can you recommend the adequate replacement of EAGLE?
    Use an eagle Versiin below 8 ...
    Be sure to use the Linux version.  The commercial OS vendors will ease
    your version right out from under you in a couple of years.
    The Linux philosophy is not to break things.  I use Ubuntu Linux and
    have Eagle 4, 5, 6 and 7 installed on Rev 16.04 LTS.
    Really though, you're better off using a package under active
    development that will keep up with OS changes.  My new choice is
    KiCAD.
    John DeArmond
  • rachaelp
    0 rachaelp over 9 years ago in reply to autodeskguest
    rk wrote on Sat, 25 February 2017 14:20
    Am 25.02.2017 um 14:46 schrieb Rachael:
    of
    have
    So if I don't subscribe I'm doomed to throw away my experience,
    libraries, setup and so on? Why?
    You know full well that's not what I was saying. You're just annoyed
    because I called you out for calling people stupid.
    But to answer your question, no you are not doomed to throw anything away
    because you don't subscribe. You can still use the existing version of
    EAGLE you have indefinitely. Some people will subscribe, some will stick
    with what they have, I'm personally sticking with v7 and waiting until I
    see how things progress, other people are however actively migrating to
    other packages. Each to their own, everybody has to do what is right for
    them and calling people stupid for their choice isn't really on.
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
  • rachaelp
    of
    have
