EAGLE User Support (English) Generating gerber with multiple PCBs with eagle
  • Views 814 views
frozennick
frozennick over 9 years ago
Hi all,
Currently I have a board with the area of 32mmx18mm. This is too small to be sent to fabrication without wasting lots of PCB space (100mmx100mm min). How do I create a gerber with multiple PCB in it so that it can be sent for fabrication?
Thanks in advance!
Best Regards,
Nick
    0 autodeskguest over 9 years ago in reply to autodeskguest
    On Thu, 1 Jun 2017 10:37:36 +0000 (UTC), Uwe Bonnes
    <bon@hertz.tu-darmstadt.de> wrote:
    Chan Wei Nick <noreply-470803@element14.com> wrote:
    Yes you are right on that, will have to contact the board house personally then. Thanks for the advice
    I  use gerbv for that purpose.
    It doesn't matter what tool one uses.  If he does his own panelization
    and does not meet that particular board house's specs, he gets to pay
    for the boards anyway.  If he lets the board house do the
    panelization, they either do it right or do it over again.  Besides,
    letting the board house do the work, usually at no charge, removes a
    lot of work for him.
    John DeArmond
    http://www.neon-john.com
    http://www.tnduction.com
    Tellico Plains, Occupied TN
    See website for email address
    0 autodeskguest over 9 years ago in reply to frozennick
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 1623569 -
    Fax. 06151 1623305 -
  • frozennick
    0 frozennick over 9 years ago in reply to autodeskguest
    On Wed, 31 May 2017 07:26:26 GMT, Chan Wei Nick
    Hi all,
    The best thing to do is to let your board house panelize the board.
    They get it right or they do it over.  If you make a mistake in
    panelizing for their process, the weight is on your shoulders.
    John DeArmond
