EAGLE User Support (English) placing componets on the bottom
  • Subscribers 189 subscribers
  • Views 4770 views
kizzzane
kizzzane over 9 years ago
just clarify, to place parts on the bottom of the board i just mirror the pcb board and start placing components? hitting the mirror button actually flips to the bottom side and not just flip the parts on the top?
  • niteowl12
    0 niteowl12 over 9 years ago
    An easy way to switch layers in Eagle is to use the middle mouse button while you are placing it. Should automatically mirror it and turn the pads/throughholes blue etc.
    -Jason
  • kizzzane
    0 kizzzane over 9 years ago in reply to geralds
    Thankyou!!
  • geralds
    0 geralds over 9 years ago
    just mirror the component and it will change the layer to  the opposite side.
    -> e.g  from top to bottom, or from bottom to top.
    Yes, just check it. image
    If you like mirror more then one component - make a group and mirror this group.
    The layers will change and the wire will also change inserting vias.
