EAGLE User Support (English) Import Altium libraries and projects into Eagle
  • Subscribers 189 subscribers
  • Views 2400 views
  • altium
  • eagle library import
  • export
  • import
sarahhyy
sarahhyy over 9 years ago
Hi everyone!
In this previous discussion, it was mentioned that library importing into Eagle was not supported. That was in 2014.
Anyone knows if this has changed? Altium can export libraries into an .lia format. Is there a way to import those into Eagle?
Also when I import the Altium exported PCAD .sch and .brd files into Eagle, I'm not sure if there's schematic-board connection / annotation. (Not sure what the technical term is called) Is there a way to ensure or create that annotation?
I'm currently using a trial Altium 17 and Eagle 6.5.
Cheers,
Sarah
  • sarahhyy
    0 sarahhyy over 9 years ago in reply to rachaelp
    Thanks for the advice - ended up not trying Library Expert out. Had too little lead time to try figuring out a whole new software.
    I did realise though, I'm on Eagle 7.7 (XP)
    0 autodeskguest over 9 years ago
    On 17/06/2017 6:33 p.m., Sarah H wrote:
    Hi everyone!
    In this previous discussion (/thread/33590/l/how-to-import-altium-files-into-eagle?displayFullThread=true), it was mentioned that library importing into Eagle was not supported. That was in 2014.
    Cheers,
    Sarah
    https://www.element14.com/community/message/224213
    If you have a paid licence for version 6 then consider downloading the
    last version 6 which is v6.6 and your licence still applies.
    ftp://ftp.cadsoft.de/eagle/program
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
  • rachaelp
    0 rachaelp over 9 years ago
    Also, you might be better with at least EAGLE v7 I would think, as the library manager was improved in v7.
  • rachaelp
    Hi Sarah,
    The *.lia format might be a Library Expert format. There is a freeware version of Library Expert but I don't know what you can do with that. You might be able to export from Altium in *.lia format and then use the freeware Library Expert to export to EAGLE but I don't know as I have never used either Altium or Library Expert. It's probably worth a try though.
    Best Regards,
    Rachael
