EAGLE User Support (English) Help with diameter of a manually entered component Eagle 8.2.2
  • Views 756 views
  • diameter
  • custom part
  • new library part
  • new library
whatifwetrythis...
whatifwetrythis... over 9 years ago
I'm trying to create a library for a PC Screw Terminal (Digikey # 36-8196-ND) and I'm not sure if I'm doing this right. The mounting detail of the engineering drawing from the manufacturer lists .101 [2.57] dia. hole (6) PLS. I'm not sure what (6) PLS is or if I need to worry about it. When doing the package I left the diameter as auto and changed drill to 2.57mm. Is this correct? I think it's correct but I'm new to this and would like to double check. Thanks
  • whatifwetrythis...
    0 whatifwetrythis... over 9 years ago in reply to autodeskguest
    Thanks for the info.
    0 autodeskguest over 9 years ago
    On 18/06/2017 6:37 a.m., Brian Hoblin wrote:
    I'm trying to create a library for a PC Screw Terminal (Digikey # 36-8196-ND) and I'm not sure if I'm doing this right. The mounting detail of the engineering drawing from the manufacturer lists .101 dia. hole (6) PLS. I'm not sure what (6) PLS is or if I need to worry about it. When doing the package I left the diameter as auto and changed drill to 2.57mm. Is this correct? I think it's correct but I'm new to this and would like to double check. Thanks
    https://www.element14.com/community/message/224234
    Hi
    The (6) PLS means 'six places'.
    It is common for a drawing to specify one hole and tell you the total
    number of times that hole appears in the object being drawn. The
    draftsman needs to ensure it remains obvious which holes are included in
    the count when there are different diameter holes.
    The technique can be used for anything that repeats within the diagram
    (locally).
    The pad diameter of 'Auto' is fine but what you will see on the board is
    not what you will be seeing in the library. The size of the pad on the
    board is controlled by your DRC settings so cheack the board to see if
    it's satisfactory. For your terminal its likely the pads will be hidden
    by a large fat track or polygon so it will not matter.
    Drill size is fine.
    HTH
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
    0 whatifwetrythis... over 9 years ago in reply to shabaz
    0 shabaz over 9 years ago
    Hi Brian, That's fine, what you did sounds correct. PLS just likely means places, i.e. repeat for all 6 hole places.
