EAGLE User Support (English) New to eagle cad feed back problems i think..
  • Subscribers 189 subscribers
  • Views 446 views
gorf25
gorf25 over 9 years ago
I have my first board, it has some optic sensors connected with led's so I can see whats going on...
Problem is when I trip one sensor all the led's are lighting so I assume the gnds or power have to be
run different the signal is separate from the rest of the connections and just leaves the board when tripped
so I am guessing the power or gnd is pulling all the leds high...
Any suggestion to isolate this some how..?
Thanks gary
  • gorf25
    0 gorf25 over 9 years ago in reply to dukepro
    could be the diodes will check that...
    I was thinking would a Schmitt Trigger work? i have 8 optic sensors and a digital probe connected..
    all with led's plus a power led....
    Thanks gary
  • dukepro
    0 dukepro over 9 years ago in reply to autodeskguest
    On 08/01/2017 02:03 AM, Joern Paschedag wrote:
    Am 31.07.2017 um 21:52 schrieb Gary burke:
    Thanks gary
    https://www.element14.com/community/message/226397
    I'm gessing that diode D758 is connected wrong.
    That's a good guess.
    Another thing to check is that the light from the LED's may be feeding
    back into the optic sensors, keeping everything tripped.  Then there's
    always ambient light running at 50 or 60 Hz (depending on your location
    on the Earth), re-tripping the board on every half-cycle.
    If the board is operated outside, then there's a constant illumination
    of the sensors, except, of course, when swallows migrate.  Then one must
    account for rate at which the bird's wings beat, which, under certain
    circumstances, can produce a pulsating waveform in the optical sensors.
    The duration of such a pulsating waveform is limited to the time the
    light from the sun is interrupted by the avian, and /that/ can only be
    answered if one knows the airspeed of an unlaiden swallow.
    6787.att1.html.zip
    0 autodeskguest over 9 years ago
    Thanks gary
    Joern Paschedag
