EAGLE User Support (English) Downloaded gerber files for bq24650EVM. Never seen these extensions b4. Can't open in Eagle. What am I missing? Thanks!.
  • Answers 2 answers
  • Views 859 views
tressan
tressan over 9 years ago
These are the extensions of the files: drl, fb, ipc, L1, L2, L3, L4, M1, M4, S1, S4.
What do I need to open these in Eagle?
Thanks for reading.
  • tressan
    0 tressan over 9 years ago in reply to geralds
    Hi Gerald,
    Thank you so much for these instructions. I despair of getting enough fidelity in a board this complicated, but your approach is perfect for another project that I am working on. Definitely saving these!
  • tressan
    0 tressan over 9 years ago in reply to autodeskguest
    Thank you so much. I didn't mention that the reason I wanted to open the files is that we need a slight modification. Most of the GC-Prevue products allow editing. This will work nicely.
  • geralds
    0 geralds over 9 years ago
    Hi, !
    First you need to preparing the settings for import into Eagle.
    Attached you'll find the instruction.
    Most problems are format of the values (Gerber 274x) and which aperture (Excellon xxx) you need.
    Then import the drill file(s) first then also the Gerber files layer by layer.
    Gerald
    imageGerber Import Instructions.pdf
    0 autodeskguest over 9 years ago
    Thanks for reading.
    If they're Gerber files, you don't open them in Eagle. Gerbers are
    manufacturing photoplotter data that you would normally export from
    Eagle once your design is complete.
    Try opening them in a Gerber viewer, such as gerbv or GC-Preview or even
    http://www.gerber-viewer.com
    There is no standard for file extensions for Gerber files but I'd guess
    that Lx are the copper layers, Mx are the solder masks, Sx are the silk
    screens, drl is probably an Excellon drill file.
