EAGLE User Support (English) Consistency errors - Attribute of part not found in board
  • Subscribers 189 subscribers
  • Views 1937 views
  • board
  • eagle
  • consistency
  • schematics
  • erc
  • attribute
  • error
sebastian.rv
sebastian.rv over 8 years ago
Hello everybody,
I'm adding to some components in the schematics an attribute 'OC_FARNELL' with its corresponding ordering number.
After doing an ERC, I get the following errors:
'Attribute of part X not found in board'
and I get the following warning when I open the board:
Board and schematic are not consistent!
No forward-/backannotation will be performed!
Use the ERC command to get a detailed error report.
How could I solve this?
I would appreciate your tougth on this.
Kind regards,
Sebastian
PS: I'm using Eagle 8.3.2
  • sebastian.rv
    0 sebastian.rv over 8 years ago in reply to rachaelp
    Hello Rachael,
    Thank you for your response.
    I tried the ULP and it seems to work. Unfortunately, after running it I noticed that this attribute gets display on layer 21 'tPlace' on the board, overlaying other drawings that I had previously in there.
    Is there anyway to avoid this? I don't want to display the attributes on the board. I could turn manually the the 'display' setting  in every single object, but I have too many of them.
    I tried to take a look in the ULP in order to change this, but I'm not very familiar with ULPs.
    Do you have any ideas?
    Kind regards,
    Sebastian
  • rachaelp
    0 rachaelp over 8 years ago
    Hi Sebastian,
    There is a ULP provided with EAGLE called copy-arrrib-sch-to-brd. Execute this with the RUN command in the schematic and it should copy all the attributes over from the schematic to the board.
    Best Regards,
    Rachael
