EAGLE User Support (English) Eagle 8.5.1 Air Wire Errors
  • Replies 11 replies
  • Answers 2 answers
  • Subscribers 182 subscribers
  • Views 4800 views
rarndt
rarndt over 8 years ago
With Eagle 8.5.1 I have air wire errors that I can not figure out how to correct (see attached).  I am modifying a PWB created in previous Eagle version, by adding one tri-color LED.  Both pins 1 (Din) and 2 (VCC) of the LED show air wires, and it is so small that I can't zoom in to see it.  Pin 3 (GND) routes fine to the GND polygon.  I have tried re-routing these two lines many times, with exact same results.  This LED is the only thing I have added to this board using Eagle 8.5.1.  Guidance please.
    autodeskguest over 8 years ago in reply to dukepro +1
    Am 02.01.2018 um 23:26 schrieb Chuck Huber: On 01/02/2018 10:13 AM, rachaelp wrote: Hi Chuck, in EAGLE v8 (not sure the specific version it became available), you don't need that catch factor trick anymore…
  • dukepro
    dukepro over 8 years ago in reply to rachaelp +1
    On 01/02/2018 06:06 PM, rachaelp wrote: wrote: I guess it's time for me to retire from the news groups into reclusion, where the only company I have is v7. No!!!! Still lots of v7 and earlier users and…
  • rarndt
    0 rarndt over 8 years ago in reply to rachaelp
    Thank you.
