EAGLE User Support (English) eagle library--updated package wont show in board
  • Subscribers 187 subscribers
  • Views 474 views
jackyson
jackyson over 8 years ago
I initially created a part in an eagle library, but now I need to change the package layout. I have already put the initial part in an eagle schematic, so removing/re-inserting it is not an option. So anyway, I opened the library editor up and edited the part's package layout, and saved the library. I then went back to my schematic, went to the library dropdown ----->Update library, and selected the library that I edited. I then created a board from the schematic(I didn't already have a board--I am not even done with the schematic. I just created the board to test if the library update worked.) Unfortunately, the package on the board remained the old one, not the edited version of the package layout. I then tried doing the same library dropdown ----->Update library while inside the board editor, but still no luck.
How do I update the part so that the board uses the new package library? Thanks.
    0 autodeskguest over 8 years ago
    On 7/01/2018 12:47 p.m., jack jitadi wrote:
    I initially created a part in an eagle library, but now I need to change the package layout. I have already put the initial part in an eagle schematic, so removing/re-inserting it is not an option. So anyway, I opened the library editor up and edited the part's package layout, and saved the library. I then went back to my schematic, went to the library dropdown ----->Update library, and selected the library that I edited. I then created a board from the schematic(I didn't already have a boardI am not even done with the schematic. I just created the board to test if the library update worked.) Unfortunately, the package on the board remained the old one, not the edited version of the package layout. I then tried doing the same library dropdown *--->Update library* while inside the board editor, but still no luck.
    https://www.element14.com/community/message/233216
    Hi
    There is a catch with the library update. It may not apply in your case
    but check it out.
    In your directory settings Control Panel > Options > Directories... >
    Libraries
    If there is a path to a same named library, earlier in the path list
    than that library you are targeting, then that library will be used to
    update the schematic/board as the library name is satisfied.
    This behaviour most often happens when users leave the default eagle
    library path there and add their personal library after it and their
    personal library has the same library names.
    HTH
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
