EAGLE User Support (English) bPlace wrong position
  • Replies 14 replies
  • Answers 5 answers
  • Subscribers 182 subscribers
  • Views 1748 views
dave.calaway
dave.calaway over 8 years ago
Hi everybody,
the first image is my pcb on eagle - board layout -, but when i generate the Gerbel file, the bPlace was in a wrong position - second image.
I use this guide to add the "Silk Screen SOL": https://goo.gl/ujCzQc   - third image - .
Someone can help me?
    shabaz over 8 years ago +2 suggested
    Hi Dave, Also, what gerber file viewer are you using, is this output from EAGLE, or third party software? If third party, it could be worth trying some additional software, (e.g. 'gerbv' but there are…
  • rachaelp
    rachaelp over 8 years ago in reply to dave.calaway +2 verified
    If you take the same design and export if using the old 8.5.2 CAM processor is your bPlace then in the correct location? I.e. is this specific to the new 8.6.0 CAM processor?
  • rachaelp
    rachaelp over 8 years ago +1
    Hello, My guess would be you are not using the vector font. Did you also use a multi-line text field to position the text vertically? If you use the vector font and place the text exactly where you want…
  • rachaelp
    0 rachaelp over 8 years ago in reply to Jorge_Garcia
    Jorge_Garcia  wrote:
    Alternatively, you can have everything using the legacy system. That will also work, the key here is that you don't want to mix them.
    Might I suggest that the CAM tell you this rather than letting people do it? A message saying that in order to add a new X2 layer then the legacy job must be converted and offer to convert it to the new format at that point.
    Best Regards,
    Rachael
  • Jorge_Garcia
    0 Jorge_Garcia over 8 years ago in reply to rachaelp
    We're on it.
    Best Regards,
    Jorge Garcia
  • dave.calaway
    0 dave.calaway over 8 years ago in reply to Jorge_Garcia
    Thx you for your help, now it's works.
    All the new gerber output are create in X2 format.
    I seen that the extension is always x.gbr in X2, but when i convert the legacy files it remain the old extension. If i left the new x.gbr extension, the gerber viewer can will have some problem?
    Could you explain me the parameters in the last pic?
  • Jorge_Garcia
    0 Jorge_Garcia over 8 years ago in reply to dave.calaway
    Hello Dave,
    I hope you're doing well. No worries, using either extension set will work just fine for any gerber viewer. Since the gerber standard never specified extensions gerber viewers can adapt.
    Please let me know if there's anything else I can do for you.
    Best Regards,
    Jorge Garcia
