EAGLE User Support (English) Change font and position of component description
  • Answers 4 answers
  • Subscribers 190 subscribers
  • Views 2902 views
mpiechotka
mpiechotka over 8 years ago
For some components the font describing component on silkscreen is very large - if text is long or component small it can be much wider/larger than component. I cannot figure out how to perform those three changes:
  • Move text so if I have, for example, a grid of resistors they are labeled as grid as well
  • Remove the value from resistor so if I label it as 200 Ω it is known by label/BOM, not necessarily by silkscreen as it takes up space
  • Change the size to something smaller.
    0 autodeskguest over 8 years ago in reply to mpiechotka
    On 25/04/18 04:49, Maciej Piechotka wrote:
    Sorry for very late reply - I haven't seen xValue layer in the list to hide it and it also hinders my ability to view the board. Which layer should I turn off?
    There are two layers: tValues and bValues for top- and bottom-side parts
    respectively. They are layers 27 & 28
  • mpiechotka
    0 mpiechotka over 8 years ago in reply to autodeskguest
  • dukepro
    0 dukepro over 8 years ago in reply to autodeskguest
    To change the font on all text objects:
    This smashes every part:
        GROUP ALL;
        SMASH (C>0 0);
    This changes the font on all objects.  Obviously, only text objects are
    affected.
        GROUP ALL;
        CHANGE FONT VECTOR (C>0 0);
    Same idea for change the line-width : height ratio.
    Enjoy,
        - Chuck
    On 04/11/2018 05:43 PM, Rob Pearce wrote:
    On 11/04/18 18:04, Gene Breniman wrote:
    Maciej,
    The first step is to use the 'Smash' tool on the board file.  Select the 'smash' tool, then click on the component.  This should separate the label and value from the component.  You can then delete the 'value' field.  You can then use the 'change - size' tool to re-size the 'label' field.  Once you have re-sized the label, you can move it to the desired location.
    One thing to add: While it is perfectly possible to delete the value
    after 'smash'ing the part, it's usually not necessary. Since most people
    don't want any values on the silk screen, most people simply exclude the
    xValues layers from the CAM job. For editing, you can turn off those
    layers in the editor.
    Oh, two things: a lot of libraries use "proportional" font but the CAM
    processor can't export this. You're better off doing CHANGE>FONT>VECTOR
    on all the name fields.
    0 autodeskguest over 8 years ago in reply to genebren
    Maciej,
    Maciej,
    0 genebren over 8 years ago
    Maciej,
    Good luck,
    Gene
