EAGLE User Support (English) How can I create a tcream layer (on a footprint) ? I need a smaller tcream pad than the Top layer.
  • Views 1622 views
t_man2
t_man2 over 8 years ago
I'm tring to create a footprint for a connector..
How can I create a t cream layer?
I need a smaller t cream pad than the Top layer.
    0 autodeskguest over 8 years ago
    Am 18.06.2018 um 12:52 schrieb tomi yehu:
    First of all, usually you do not need to create it at all, because it is
    generated automatically from the SMD pads.
    The final shrinkage relative to the copper pads is defined in the
    board's DRC setup (under Masks), not in the library.
    Display the tCream layer in the board editor to see it.
    Only in special cases you have to manually draw cream masks as described
    by Rachael.
    – Hans
  • rachaelp
    0 rachaelp over 8 years ago
    The first thing you need to do is go into the properties for the smd and turn off automatic cream generation by unchecking the "Cream" checkbox. Now you can use the polygon tool to draw a smaller tCream area on the tCream layer. Note that the line width of the polygon will affect your polygon size and don't make it 0 or it may cause exceedingly long gerber generation times.
    I wrote a tutorial series about creating library parts in EAGLE which you can find here: EAGLE Tutorial Series
    Creating custom Stop and Cream apertures is covered in part 4.
    Best Regards,
    Rachael
