EAGLE User Support (English) Variant names
  • Subscribers 177 subscribers
  • Views 939 views
Variant names
when you create a new device variant EAGLE will ask you for its name. If
you leave the box empty you'll see double quotes ( " ) as variant name
but actually there are no suffix added to component name. Let's say this
is the 'default' variant of the device.
Now you have several variants and you want to change the 'default' one.
How to?
You can't rename such a variant leaving the name empty (this time EAGLE
won't use double quotes). You can't insert the double quotes yourself
because it will be the actual variant name, appended to the device name.
Thanks in advance
Marco / iw2nzm
    On 1/31/08 11:11 AM, in article fnsrvq$bvj$1@cheetah.cadsoft.de, "Marco
    Trapanese" <marcotrapanese@libero.it> wrote:
    How to?
    A null variant isn't double quotes, its actually two single quotes.  And
    yes, you can rename something that if you want.  I've done it.
    James.
    James Morrison
    www.eagletoolkit.com
    Long-time EAGLE User and EAGLE Enterprise Toolkit Author
    Yeah! It was my fault! Now works fine image
    Marco / iw2nzm
