EAGLE User Support (English) What does "has fallen apart" mean in the ERC?
  • Views 1428 views
Just got several statements like this as errors in the ERC:
"Segment of net /BLUE has fallen apart"
Yet those sections (two each) connect correctly and when clicked on are
still labeled correctly. And on the real product the blue LED lights
correctly image
It's Eagle 7.2. What gives? Is this a bug?
Regards, Joerg
  • andreasoelsner
    andreasoelsner over 9 years ago in reply to autodeskguest
    Hallo zusammen,
    what has been the solution? I got this problem already and ignored it. Meanwhile I have at least 5 different designs with that error message, it may be time to have a solid solution?
    Best regards,
    Andreas
    autodeskguest over 11 years ago in reply to autodeskguest
    On 2015-09-07 7:03 AM, Richard Hammerl wrote:
    Am 02.09.2015 um 19:02 schrieb Joerg:
    correctly image
    There seems to be a net that seems to consist of two segments but
    should be only one segment. This is an tricky error message that
    shouldn't occur...
    I always farm out layouts and most are done in PADS. The netlist was
    correct and the boards are in series production.
    To check this cold you üplease send the schematic file?
    I just sent it off to you and wrote the email in German so I don't
    become rusty image
    A solution could be to connect the two net segments in the schematic
    and delete the connection again. But to be sure, we should look into
    the file.
    In this case it could somehow be done but on more busy schematics where
    that would require dozens of additional lines it isn't practical.
    Regards, Joerg
    correctly image
    shouldn't occur...
    the file.
    Richard Hammerl
