EAGLE User Support (English) Auto-router stops after very few traces
  • Subscribers 178 subscribers
  • Views 283 views
Not that I want to do layouts myself but I wanted to see what the
autorouter would do with a rather simple two-layer board. Well, after
running a few top-layer traces it just quit. No warning, nothing. It
didn't even touch the bottom layer. Just curious: Why does it stall
without any messages?
Regards, Joerg
    On 2/25/08 9:57 PM, in article fpvv6u$116$1@cheetah.cadsoft.de, "Joerg"
    <notthisjoergsch@removethispacbell.net> wrote:
    Hi Joerg,
    Sounds to me like the routing grid.  This is the grid that the router will
    place traces on.  If it is larger than the pitch of parts you have then it
    won't be able to even get to a pin on that package.  I usually set it to 1/2
    of the trace spacing.  But if it gets too small it will make the routing
    take forever.
    James.
    James Morrison
    www.eagletoolkit.com
    Long-time EAGLE User and EAGLE Enterprise Toolkit Author
    Hi Joerg,
    take forever.
    Thanks, James, that did it. The weird thing was that I could continue a
    lot farther by hand on the same grid. Oh well. I might give you a call
    some day. A small design where I'd have to do the initial part of the
    layout because it's iffy in terms of RF but it then needs to be cleaned
    up and vetted by someone who has done a lot of Eagle layouts.
    Regards, Joerg
