EAGLE User Support (English) Component editing on schematics
  • Subscribers 178 subscribers
  • Views 183 views
I guess I am used to Protel and have only just started with Eagle. Using
Eagle, when I "add" a component such as a resistor to a schematic from the
library, I sometimes want to hide the name and/or the value to avoid
clutter. I sometimes might want to just move these to a different spot to
avoid overwriting other text. I cannot find a way to do any of these actions
which I am used to doing in Protel. Is there a way that actions such as
these can be done.
Thanks in anticipation of a reply.
Don
  • Richard_H
    Richard_H over 17 years ago
    these can be done.
    Don
    Use the SMASH command to detach the texts form the part. Now you
    can move/change them as you like. To hide one of the texts use
    DELETE.
    DELETE on the other text works like unSmash.
    HTH
    Richard Hammerl
