EAGLE User Support (English) Additional traces with wire
  • Subscribers 178 subscribers
  • Views 392 views
When I create additional traces with the wire command and connect them to a
net, the nets are still indicated as separate.  Is this normal?
    Former Member over 17 years ago
    give them the same name & then they will be connected
    r
    Also be sure to use the 'NET' command to connect things up, NOT the
    'WIRE' command.
    Jack
    to a net, the nets are still indicated as separate.  Is this normal?
    'WIRE' command.
    Jack
    The "WIRE" command only draws LINES, not TRACES.  A TRACE connects
    pins/pads of parts.  A TRACE is associated with a NET name.  If you
    insist, a WIRE can be converted into a TRACE by NAMING the WIRE to an
    existing NET name.  Confusing, isn't it ?
    HTH
    -Dave Pollum
    "David Pollum" <vze24h5m@verizon.net> wrote in message
    news:fr9m0i$5uv$1@cheetah.cadsoft.de...
    'WIRE' command.
    Jack
    HTH
    -Dave Pollum
    How do I rename a wire?
    With the NAME command of course.
    Bye
    Marco / iw2nzm
    "Marco Trapanese" <marcotrapaneseNOSPAM@gmail.com> wrote in message
    news:frh082$d00$1@cheetah.cadsoft.de...
    Ah, yes.  Thanks
    Bye
    Marco / iw2nzm
