EAGLE User Support (English) Delete Pad
  • Subscribers 178 subscribers
  • Views 1585 views
Delete Pad
Former Member over 17 years ago
I am trying to edit a connector in the libary editor by removing pins not
used, I can delete the pins but not the solder pads. I get the error "Can't
delete pad/smd from a package that is in use" What am I doing wrong?
    Greetings jlt,
      on Wed, 12 Mar 2008 you wrote saying :
    Why are you removing pins? Surely the connector either has them or isn't
    the same connector!
    Anyway, the error message is saying that you can't do this to a
    "package" that is already associated with a "device". I think that's
    because the device may have allocated pins of its "symbol" to all the
    pads, so losing a pad would break the device. Removing pins from symbols
    doesn't have this restriction, because it merely results in the device
    having some no-connect pads.
    What you need to do is copy the package to a different name first, then
    modify that. Then you should similarly copy and rename the symbol before
    modifying it. And finally you create a new device that uses the modified
    symbol and package.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
    Thankyou for the reply Robert.
    The reason I am removing pins is because the Harting connector I need to use
    (eurocard connector) is a 48pin. The only library I can find is a Harting
    96pin.
    They are identical except for the 48pin not having the odd numbered pins so
    removing half the pins will result in the exact pins, pitch, pads etc.
    Again, thanks for the advice, I will try this tomorrow.
    jlt
    "Robert Pearce" <news@bdt-home.demon.co.uk> wrote in message
    news:NuwNlFOSOA2HFwUj@daniel.huneausware.local...
    Greetings jlt,
    "Can't
    the same connector!
    Anyway, the error message is saying that you can't do this to a "package"
    that is already associated with a "device". I think that's because the
    device may have allocated pins of its "symbol" to all the pads, so losing
    a pad would break the device. Removing pins from symbols doesn't have this
    restriction, because it merely results in the device having some
    no-connect pads.
    symbol and package.
    believe a word.      |
    I still have the same problem, any other ideas? The part I am trying to edit
    is
    CON-VG    MABC96LP
    Still cannot remove pads
    jlt
    Greetings jlt,
    "Can't
    the same connector!
    this restriction, because it merely results in the device having some
    no-connect pads.
    symbol and package.
    believe a word.      |
    Ahhh, hold on, I think I got it now. I have managed to delete the pads.
    I guess I now have to link it back to the Device and Symbol?
    jlt
    "jlt" <a@b.com> wrote in message news:frlohp$dca$1@cheetah.cadsoft.de...
    edit is
    CON-VG    MABC96LP
    jlt
