EAGLE User Support (English) Resistor Value
  • Subscribers 178 subscribers
  • Views 922 views
Resistor Value
I was analyzing the schematic attached and found the resistors R51 and R48
marked as "0R". What does that mean? Anybody understand this ?
Thiago
    Thiago Henrique wrote:
    Thiago
    Hello Thiago
    It means zero ohms. As well 4R7 is 4.7 ohms, 1k2 is 1200 ohms and 6M8 is
    6800000 ohms.
    Best Regards
       Asko
  • esilviu
    esilviu over 17 years ago
    generally these are fuses or ferrite bead.
    "Thiago Henrique" <thiago_hr@yahoo.com.br> wrote in message
    news:ft4a4n$h0$1@cheetah.cadsoft.de...
    Thiago
    Hello Thiago Henrique !:
    Sure image
    You have to mount only one of them. You can choose where you will get
    the power to. Maybe ...
    It would be better if you send us more informations. Now we can guess
    only image !
    regards.
    Grzegorz Zalot
    complex ltd.
    office tel/fax : +48 32 2505840
    mobil : +48 501 301515
    http://www.complex.org.pl/
    "Grzegorz Zalot" <complex@alpha.pl> schrieb im Newsbeitrag
    news:ft4g12$5gu$1@cheetah.cadsoft.de...
    R48
    Sure image
    You have to mount only one of them. You can choose where you will get the
    power to. Maybe ...
    I doubt that. I am 99% sure that this denotes a supply to both Vdd AND Vcc;
    a power distribution point. Means, 0R "bridges" in BOTH places. The reason
    may be that you can simply detach individual supplies, to facilitate
    debugging. These bridges can also be replaced by some low valued resistor in
    case there are noise problems.
    T.
    It would be better if you send us more informations. Now we can guess only
    image !
    regards.
    Grzegorz Zalot
    complex ltd.
    Thiago
    I would suggest that the designer has split power supplies. The rest of
    the circuit requires both Vcc and Vdd supplies. For one reason or
    another, these have not all been named as the same net. perhaps one is
    an analogue rail, the other digital. They are brought together where
    these resistors (jumpers really) are on the board. The same trick can be
    used to have split grounds.
