EAGLE User Support (English) Library Inconsistent
  • Subscribers 178 subscribers
  • Views 300 views
I am having a major headache over this right now.  Please bear with me
as I painstakingly TRY to tell you what the heck is going on here.
In a nutshell, I've updated my package layout to a particular part in
the library I am using, and when I hit "Update All" only a portion of my
components actually update.
When I check the info they are all listed as being from the same library.
When I search my computer there is only ONE copy of that library, I even
moved the .l## files to the recycle bin.
This problem is existing with the newer parts that I have placed.  There
was obviously some cross-over point in time for parts that seem to come
from a now non-existent library.
Since the creation of this library I have added some packages to my
devices, for instance, I added a 1206.a which has slight modifications
over my old, regular 1206 package information.  I added it to the device
and made the connections.  Once in either the schematic or the board I
can do a "change package" and see the three or more package options I
have for resistors... but ONLY for the newest ones.  For the older ones
only my original package option remains.  Furthermore when I look at
info on the older, non-updatable parts, instead of reading: "Package:
1206" they read "Package:1206@1" which is definitely no package I have
ever created.
My only guess is that EAGLE stores a copy of necessary library
information in the .sch and/or .brd files themselves.  I suspect this
b/c I've transported my files to computers that did not have my
libraries and everything showed up fine.  Somehow EAGLE must have
assumed that my library no longer existed when I moved my .sch file to
another system, even though I moved the library file with it.  After
doing that and moving back to the original system EAGLE must have
decided again to use some in-schematic-stored version of my libraries.
How in the heck can I get EAGLE to actually USE the library it's
supposed to have been using all along?
How did this happen?
WHY did this happen?
PLEASE HELP!
-jh
    I noticed one more thing.  My gate is "RESISTOR" on all the older parts,
    while it is "R" on the newer parts.  Perhaps recreating "RESISTOR" and
    plopping in all my newer packages will work.
    I changed names to keep up with the conventions from older libraries, I
    don't know why I named 'R' 'RESISTOR' in the first place.  The .sch/.brd
    files must be looking for 'RESISTOR,' which no longer exists, and is
    instead resorting to some in-file-stored version for library information.
    Does this sound right?!
    I recreated BOTH a package and a symbol called "RESISTOR."  Suddenly,
    EAGLE prompted me after doing and update all to say that the package no
    longer existed (I made a typo in the variant name).  I corrected the
    type so it reflected what it had been looking for and presto, everything
    fell into place.
    Room for improvement?  Can't EAGLE either keep track of when
    devices/packages/symbols change names or perhaps throw a warning when a
    certain name is no longer found allowing the user to select a new one
    that is compatible.
    "Update All" does not always actually update all
    for grins, go to "Update" and select the desired library
    Former Member over 17 years ago
    before update all: use *, enter (command line)
    after that: all libs are in use
    r
