EAGLE User Support (English) CAM process hanging on"printing aperture D10"
  • Subscribers 187 subscribers
  • Views 1256 views
dandeurloo
dandeurloo over 6 years ago
I am trying to print my first 4 layer PCB.  I am trying to run a CAM process for printing my Gerbers.  The CAM process keeps hanging up on a screen that says "printing aperture D10".  Do these "printing aperture D's" typically take a long time to process?
Any ideas what might be the issue and how I can get these Gerbers created?
I am using EagleCAD 7.7
Thanks.
    0 autodeskguest over 6 years ago in reply to dandeurloo
    On 14.05.2020 18:39, Dan Deurloo wrote:
    Yes, this was it!  Thank you.  Is there a preferred size of wire for creating polygons?
    As Rob says..
    Remember the wire width requirement originates from the time when the
    fill actually happened with a round pen/aperture, and this is why inner
    and outer corner sharpness is limited to this pen diameter. If this pen
    is very thin (or 0, wich is converter to very very very thin in eagle),
    imagine the time it will take to fill it.
    Today's modern transfer tech does not have this limitation as the are
    very fine pitch pixel based. But modern tools support support converting
    the old stuff. I have been missing "flash" mode fills on Eagle for a
    long time. It would also make screen drawing a lot faster, wich you will
    notice when working with larger pcb's.
    Not a single value. The width parameter controls the narrowest fill you
    can achieve, and thus the smallest gap it can flood through. It also
    controls the width of the bridges across "thermal" isolation on PTH
    pads. Generally, you should go for the widest that doesn't cause you any
    problems with flood fill. That said, the corners are rounded to the
    width setting, too, so making it too wide "blurs" the shape.
  • dandeurloo
    0 dandeurloo over 6 years ago in reply to autodeskguest
    Unless you provide the gerber code describing aperture D10 it will be
    hard to tell, but I suspect you may have used very thin wire for
    polygons, wich will become a very large file and take a lot of time to
    create.
