EAGLE User Support (English) Remove milling layer
  • Subscribers 186 subscribers
  • Views 1258 views
  • board
  • remove
  • milling
  • delete
  • layer
mfsam
mfsam over 6 years ago
Hi everyone,
I created an eagle PCB design based on board design imported. (a raspberry pi hat).
In this design, a milling hole was incorporated but I don't need that so I want to remove the lines in this layer but I can't delete them.
I tried to create new lines and see how i could remove them but also couldn't remove the new lines (except with ctrl+z) .
I tried different approach.
  1. try to select the lines with the group tool
  2. cmd : group all;
These approach let me with nothing selected so I can't delete them.
My question is, how can I remove everything on layer 46 since I can't select a thing?
    0 autodeskguest over 6 years ago in reply to autodeskguest
    On 11/08/2020 06:49, Joern Paschedag wrote:
    If you ask questions it helps if you provide your eagle version.
    Indeed, especially since recent versions (9.x) have a selection filter
    that causes a lot of people to have a lot of trouble like this.
    Am 10.08.2020 um 22:15 schrieb samuel Geoffroy:
    Hi everyone,
    2. cmd : group all;
    https://www.element14.com/community/message/294843
    If you deselect all layers except layer milling(46), group and delete
    does not work, then this layer is brought in by a library. That means
    only in that library you can remove  layer 46.
    You could also create the same device without this layer (copy & paste
    it to a different name).
    Joern Paschedag
