EAGLE User Support (English) Eagle 5 installation problem on Windows Vista
  • Subscribers 178 subscribers
  • Views 342 views
I have been trying unsucessfully to install Eagle 5 on a Vista laptop. I
get:
"Error while copying 'C: \Program Files\EAGLE-5.0.0\bin\eagle.exe' "
I have been then adviced to fix the problem and try the installation again.
Does anyone know what the problem is?
I have tried three new downloads from Cadsoft, the effect is the same.
During my subsequent attempts at installation I have noticed one odd thing:
The installer proposes the directory C:\Program Files\EAGLE-5.0.0 and
informs that this directory
already exists and the files it contains will be overwritten and, in the
same dialog box, browsing the Program Files
shows EAGLE-5.0.0\bin. However, outside the installation process, the
contents of C:\Program Files shows
no directory named EAGLE-5.0.0. I only hide from view the protected
operating system files.
This is the only installation problem I have encountered on this machine. It
runs sucessfully many programmes,
most of them installed to C:\Program Files.
Finaly I would like to add that I am new to Vista.
Any help will be greatly appreciated.
Jan
  • esilviu
    esilviu over 17 years ago
    It's not the right way, but it could work very well:
    - after opening installer (exe that you downloaded), search in Temp folder
    used by Vista. You will find the eagle direcory (with Wzse0.tmp name for
    example)
    - copy this folder in Program files directory, and rename-it to Eagle.
    - cancel the installer you opened at first step.
    - create a shortcut on desktop, or whatever to /proram
    files/eagle/bin/eagle.exe
    Or just use winzip to unpack eagle files from instalation kit
    "enperit" <enperit@globaldial.com> wrote in message
    news:fvegka$5ns$1@cheetah.cadsoft.de...
    get:
    again.
    thing:
    It runs sucessfully many programmes,
    Jan
    I found this little quirk with a few other problems running on Vista.
    If the UAC (User Access Control) is ON, and you do not get proper program
    execution or control, you must 'run as administrator.'. Seems a bit stupid
    to have to do this when one already had admin access...
    Go to the install file and right click on it. Choose run as administrator
    and then it should run properly.
    Most likely, the install program is not handling Vista's 'do you really want
    to do that' nagging. Another option is to go to the users in control panel
    and turn off UAC (not recommended) This requires a re-boot to take effect.
        Oppie
    get:
    again.
    thing:
    Jan
    "oppie" <fios-@verizon.net> wrote in message
    news:fvlu78$gu$1@cheetah.cadsoft.de...
    want to do that' nagging. Another option is to go to the users in control
    panel and turn off UAC (not recommended) This requires a re-boot to take
    effect.
       Oppie
    Thanks Oppie,
    Reinstating the admin access allowed the installation to go through, however
    I noticed
    another weird message - the installer could not find a subdirectory eagle
    4.14.
    This has been a virgin eagle installation, where does the eagle 4.14 come
    from?
    I have ignored the message and, at a glance, the software seems to be
    functional.
    I was hoping that Cadsoft could shed some light on these problems.
    eSilviu - thank you for you syggestions too.
    Jan
    get:
    again.
    thing:
    Jan
    "jan" <enperit@global.net.au> wrote in message
    news:fvm7fh$l61$1@cheetah.cadsoft.de...
    stupid to have to do this when one already had admin access...
    effect.
       Oppie
    Thanks Oppie,
    however I noticed
    4.14.
    from?
    functional.
    Jan
    I'm still a nubie on Eagle, having worked a bit with 4.15 and still trying
    to master it. Been using Vista since 2/2007 and now am on SP1. The Run as
    Admin tip came from trying to use the windows Live Safety Scanner (which is
    a decent clean-up tool) and found it wouldn't run anymore. Asked on the MS
    Vista forum and was told about the run as admin option.
    I believe that if you are doing a new install and the subdirectory does not
    exist, it will create one for your but will sometimes give an error message
    that it does not exist.  I am now just trying version 5 at home. We have a
    licensed copy of 4 at the office.
        Oppie
