EAGLE User Support (English) Polygon Error in EAGLE 5.0
  • Subscribers 179 subscribers
  • Views 493 views
Former Member over 17 years ago
Hello all,
I'm trying EAGLE 5.0 Freeware and I'm getting an illegal polygon error and
I'm unable to generate the layer.  It's apparently an overlapping polygon,
but why am I able to generate the layer without an error in EAGLE 4.16?
Terri Miller
    I fear that without some more detailed information, noone here can help
    you. What exactly are you doing that generates that error?
    Tilmann
  • Richard_H
    Richard_H over 17 years ago
    Hello all,
    Terri Miller
    Please send me the file with private mail. So I could check it.
    Richard Hammerl
    Hello Richard,
    I've sent an email with files attached to the email address provided.
    Thanks!
    Terri
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:g0eai9$rsd$1@cheetah.cadsoft.de...
    Hello all,
    and I'm unable to generate the layer.  It's apparently an overlapping
    polygon, but why am I able to generate the layer without an error in
    EAGLE 4.16?
    Terri Miller
    Richard Hammerl
  • Richard_H
    Hello Richard,
    Thanks!
    Terri
    Here in short my answer to Terri's problem:
    "The polygon contour of the polygon is not drawn proper enough.
      If you take a look at position (15.2 25.9) and move the
      polygon wire a little bit to the left it will be calculated.
      At this position the contour wire overlaps slightly and causes
      the error.
      In 4.16 it was not reported as a problem, this is correct.
      But there are lots of improvements and changes in the algorithm,
      so that this overlap causes an error message now.
      And to be honest, it should have been reported in 4.1, as well."
    Richard Hammerl
