EAGLE User Support (English) What does autorouter warning "used but not enabled!" mean?
  • Subscribers 178 subscribers
  • Views 550 views
On a 4-layer board, where layers 2 and 3 are the internal layers, I'm
getting the error "Layer 2 (Route2), 3 (Route3) used but not enabled!
Objects therein may collide with vias placed by the autorouter."
Please can someone explain what this means and how to correctly resolve this
error?
Robin
  • Richard_H
    Richard_H over 17 years ago
    error?
    Robin
    There is a layer that contains copper elements but you don't allow
    the autoruter to use this layer for routing. So the Autorouter
    has to ignore this layer and it could happen that the Autorouter sets,
    for example a via, that covers a track inside this layer. This could
    result in short circuits or a drill through a track or something like
    that. Best would be to allow the Autorouter to use this layer, too.
    Richard Hammerl
    Thanks for your reply Richard.
    The two inner layers are solid copper layers only to be used as power
    distribution layers to aid routing. The board does not have blind / buried
    vias.
    So, although I don't have any tracks in these inner layers, I do want the
    autorouter to be able to place vias to connect to these layers where
    necessary.
    If this is what I need to do, please could you explain how to explicitly
    allow the autorouter to use these layers? All I can find is the "supply"
    checkbox in the display layers menu.
    Thanks for your help
    Robin
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:g0jebv$drh$1@cheetah.cadsoft.de...
    this error?
    Robin
    has to ignore this layer and it could happen that the Autorouter sets, for
    Richard Hammerl
    vias.
    necessary.
    Robin
    this error?
    Robin
    Richard Hammerl
    Robin;
    My 4-layer board uses layers 2 and 15 as internal layers.  In
    TOOLS/DRC/LAYERS, I have my layer stack-up (called "setup" by EAGLE) as
    (12*1516).  Layer 1 is the top layer, 2 is the GND layer, 15 is the
    VCC (+5v) layer, and 16 is the bottom layer.  I have layer 2 defined as
    "$GND", and layer 15 as "$+5v".  The "$" makes layers 2 and 15 power
    plane layers.  Don't use the quotes when assigning the names.
    HTH
    -Dave Pollum
