EAGLE User Support (English) How to re-use parts on sch and brd file ?
  • Subscribers 187 subscribers
  • Views 2445 views
genma_saotome
genma_saotome over 5 years ago
Dear Sir,
I'm newer for Eagle and I'm trying the old version 5.7.
I got a sch and brd file, and I want to re-use the part create already in sch and brd, How can I copy it to my own lib ?
Thanks!
Genma
    0 autodeskguest over 5 years ago in reply to genma_saotome
    Am 23.02.2021 um 10:23 schrieb Saotome Genma:
    Dear Joern and Bernhard,
    Really thx a lot for you guys help. It's work now.
    THanks!
    Genma
    https://www.element14.com/community/message/300379
    Have fun, cost you a beer image
    Joern Paschedag
  • genma_saotome
    0 genma_saotome over 5 years ago in reply to autodeskguest
    THanks!
    Genma
    Am 22.02.2021 um 07:20 schrieb Saotome Genma:
    Dear Joern
    Thanks a lot for your reply. But on the sch file UI or BRD file UI, I cannot found the ULP call export Libraries or any similar.
    Or even the Eport command didn't have any similar function to export the lib ?
    Thanks!
    Genma
    https://www.element14.com/community/message/300401
    That is  an ULP (user languish program) and located in  the
    ULP-subdirectory created by eagle.
    (Your pictures didn't make it to the news reader but on e14 I found them)
    At the very top of your .sch (where the little squares are) you find one
    named ULP
    (on your picture below the word "option")
    that directly points to the ULP-subdirctory and opens it up, so one can
    select the file one wants.
    You can check the ULP-dircetory by  yourself to look for the file
    mentioned (in my old eagle-5.12 it is named "exp-project-lbr-ulp")
    I'm using a win operating system (you didn't mention yours)
    the eagle setup makes everything ready to go, but you could check in the
    CONTROL PANEL / OPTIONS / DIRECTORIES that the path's to the eagle
    subdirectories are correctly set.
    If you get eagle-5.12 then install it in a different directory and not
    over your existing version.
    Joern Paschedag
    Click onto the ULP-Button or enter 'run' in the command-line.
    Then search for the ULP called 'exp-lbrs'...
    PS. Just to be sure - in the ULP-selection browser be sure to use the
    correct directory - even though IMHO the default one should already be
    the correct one. In my case (I use a newer version of eagle), in the top
    right of the window I can choose the path and it is set to 'xxx/eagle/
    examples/ulps/examples'.
    kind regards
    Bernhard
  • genma_saotome
    Dear Joern
    Thanks!
    Genma
    Am 19.02.2021 um 03:15 schrieb Saotome Genma:
    Dear Sir,
    Thanks!
    Genma
    https://www.element14.com/community/message/300231
    See that both files are open. In .sch open an ULP called:
    "export libraries" or maybe exp_project_lbr or similar.
    That will create a library with the same project name and it contains
    all devices used in your project.
    Make the new library usable: USE path and name of that library, or
    simply copy it into your library direction.
    To put parts of any library into your own library open YOUR library
    and in the CONTROL PANEL locate the library, expand it, locate the
    device, right Click on it and in the opening dialog select "copy into
    library". Save your library and you are done.
    By the way you should upgrade to the latest Ver-5 eagle that is
    Ver. 5.12 .Cost you nothing and your license is valid for that.
    ftp://ftp.cadsoft.de/eagle/program/
    Joern Paschedag
