I am having problems installing (Windows XP)
I do not have any older copies but I did use the free version which I have
removed.
When I try to install I get the initial splash screen I select English and
Install program ....nothing happens.
Help
removed.
Help
removed.
Help
Do you have sufficient user rights to install programms?
Maybe your firewall blocks installing programs?
Richard Hammerl
have removed.
and Install program ....nothing happens.
Help
I have the same problem.Now have to run it through Linux.
have removed.
English and Install program ....nothing happens.
Help
Since we didn't get any response it's hard to say what's going on.
But I think it must have to do with the rights management.
What you could try else:
Extract the EAGLE archive file and simply copy the files to any
folder on your computer. Create an icon on the Desktop and start EAGLE.
Richard Hammerl
Its not an access problem. I am the admin on my machine.
Also its not an install over the web app so I don't see what firewall
setting have to do with it.
I installed on another machine and copied over. It sucks as uninstall will
not work.
"Richard Hammerl" <ric@cadsoft.de> wrote in message
news:g10l1o$oj2$1@cheetah.cadsoft.de...
have removed.
Help
Richard Hammerl
I have removed.
Help
Thanks Richard it worked perfectly even though it said the file was
corrupt when extracting it.Now all working ok under Windows XP.
have removed.
Help
Thanks Richard it worked perfectly.
