EAGLE User Support (English) prevent pads holes being filled
  • Subscribers 187 subscribers
  • Views 2212 views
  • pads
  • pcb
will.mendil
will.mendil over 5 years ago
In Eagle (v9.6.2), the routes fill the holes of my pads. hence when I want to print it, the pads are all black, no drill holes. What am I missing?imageimage
  • will.mendil
    0 will.mendil over 5 years ago
    I just needed to print it anyway. I guess the preview engine is a little buggy. Printing the preview does indeed show the holes... I feel foolish
  • geralds
    0 geralds over 5 years ago
    Hi will.mendil
    in the "OPTIONS" - "Settings" - "Miscellaneous" you must check the checkbox "show holes" .
    Then in the printer settings you're right you must check in the checkbox "black" as well "solid".
    The next:
    You have problems with the distance between the pads and the distance to the edge of the board.
    DRC settings: Either set the distances in the rules (but be careful with that values, too small distance values cannot be etched) or use smaller pads.
    Best Regards
    Gerald
    0 autodeskguest over 5 years ago
    Am 29.05.2021 um 10:46 schrieb Will wat:
    In Eagle (v9.6.2), the routes fill the holes of my pads. hence when I want to print it, the pads are all black, no drill holes. What am I missing? https://i.stack.imgur.com/9Fkv4.png  https://i.stack.imgur.com/4uf16.png
    https://www.element14.com/community/message/302733
    HP printer image me too with eagle6.6.0.
    Imho it was the printer setting / extended options/ between
    raster/bitmap graphics.
    Hope it helps;-)
    Joern Paschedag
