EAGLE User Support (English) How to Lay out LED's for a clock
  • Subscribers 189 subscribers
  • Views 775 views
rjwheaton
rjwheaton over 16 years ago
I'm trying to lay out a pcb with an led at each point of the clock. I want to draw guidelines from a center point out to the "face" of the clock for placing the LED's but I can't figure out how to tell Eagle the exact angle I want for each line. I appreciate your assistance.
Roy
    0 e14 Contributor over 16 years ago in reply to e14 Contributor
    "JayaB" <communitymanager@premierfarnell.com> wrote in message
    news:53484409.140471278390867307.JavaMail.jive@flcspu-csapp-01.premierfarnell.com...
    Place a relative origin with MARK. The use the ADD command with Polar
    co-ordinates.
    In your case, it would be for example:
    GRID MM;
    ADD LED3mm (P 20 0)
    ADD LED3mm (P 20 30)
    ADD LED3mm (P 20 60).............and so on.
    where 20 is the radius.
    Or MOVE if the components have already been placed.
    move D1 (P 20 0)
    move D2 (P 20 30)
    0 e14 Contributor over 16 years ago in reply to rjwheaton
    Place a relative origin with MARK. The use the ADD command with Polar co-ordinates.
    GRID MM;
    ADD LED3mm (P 20 0)
    Jaya
    "Roy Wheaton" <communitymanager@premierfarnell.com> wrote in message
    news:971645910.52491278345802771.JavaMail.jive@flmspu-csapp-02.premierfarnell.com...
    Roy
    Try this ulp:
    int j,n,delta;
    real teta,R=1.;
    output("C:
    test.scr") {
    delta=30;
    n=360/delta;
    for(j=1;j<=n;j++) {
       teta=j*delta;
       printf("add led3mm@led (P%f %f)\n",R, teta);
    exit("script 'C:
    test.scr'");
  • rjwheaton
    0 rjwheaton over 16 years ago in reply to e14 Contributor
    Yes, that's correct. My problem isn't knowing where the "hands" go, but learning how to draw guidelines with polar coordinates. If I had a single example of, say, how to draw a guideline from a point to a given distance at a given angle, I would be home free.
    Use polar coordinates for placing components and/or guidelines (by
    keyboard at the command line). See the chapter about general usage and
    coordinate entry in the built-in help or the manual.
    And yes, that's a fine opportunity to learn the commands and their
    syntax. image
    Tilmann
    I may be wrong, but isnt a clock just a 360 degree circle? 0=12 , 30=1, 60=2, 90=3, 120=4, 150=5, 180=6, etc?
