EAGLE User Support (English) pcb with telit gps modul GM862
  • Subscribers 178 subscribers
  • Views 302 views
Former Member over 17 years ago
Hi
Have anybody PCB with telit gps modul GM862  and with power supply?
    I don't understand what you mean writing "with power supply", anyway a
    GM862 footprint is included in Spark Fun Electronics footprint library:
    http://www.opencircuits.com/SFE_Footprint_Library_Eagle
    hope this helps,
    C.
    Joze wrote:
    Hi
    Former Member over 17 years ago in reply to autodeskguest
    Hi
    GM862 Cellular Quad Band Module with GPS
    http://www.sparkfun.com/commerce/product_info.php?products_id=7917
    have supply voltage: 3v8 and
    have SIM holder and
    have antenna connector gor GSM and for GPS but
    I need cca 6 .... cca 28V to 3v8 converter (2A) for power supply!
    BR
    Joze
    "Nicola" <cirutech@libero.it> je napisal v sporocilo
    news:g3o636$1uq$1@cheetah.cadsoft.de ...
    hope this helps,
    C.
    Joze wrote:
    Hi
    I would just use a 3A capable adjustable voltage regulator with a heat sink,
    set it for 3v8 and be done.  Reason I'd use a 3A one is to give some
    protection to the regulator for over current situations.  I would also use a
    fuse to keep shorts from damaging anything, set to go off at say 2.5A or 3A.
    Recommended filter capacitors can be found in the data sheet for the
    regulator, and probably in the data sheets for that radio as well.
    "Joze" <microera@siol.net> wrote in message
    news:g3p25h$elm$1@cheetah.cadsoft.de...
    Hi
    have SIM holder and
    BR
    Joze
    hope this helps,
    C.
    Joze wrote:
    Hi
