EAGLE User Support (English) Library part pad diameter being overridden to larger size when placed on board
  • Subscribers 179 subscribers
  • Views 562 views
ogradyg
ogradyg over 15 years ago
I've designed a library part for a 2 x 5 pin header with 50 mil centers, a drill of 20 mil and a pad diameter of 40 mil.
When the part is placed on the board however, the pad diameter is increased to a larger size (48 mil). The resulting pads violate the inter object spacing requirements.
I have experimented with the restring settings with no luck, what settings should I be looking to change to prevent this behaviour?
GPO
    0 Former Member over 15 years ago
    You are in the right area to correct the problem. The "minimum" parameter
    in DRC > Restring will make pads "grow" to that minimum size.
    If this does not fix your particular problem, I'm sure someone more
    knowledgeable than I will be able to assist.
    Jeff Rockel
  • ogradyg
    0 ogradyg over 15 years ago in reply to Former Member
    Jeff,
    I went back and took another look at my restring values and originally I only modified the "Top" settings - thinking only of the component placement layer rather than the actual copper locations. With both the "Top" and "Bottom" settings adjusted ("Inner" doesn't count on a 2-Layer design) my component looks as it should and there are no related DRC errors.
    GPO
