EAGLE User Support (English) Height in EagleCAD?
  • Subscribers 187 subscribers
  • Views 599 views
  • pcb_traces
  • height
Height in EagleCAD?
Is there anyway to change the height above the board of the PCB traces and pads in EagleCad?
    0 e14 Contributor over 16 years ago
    On 08/11/2010 11:50 AM, Olin Lathrop wrote:
    Matt Collinge wrote on Wed, 11 August 2010 11:21
    No, that is something you specify to the board house separately from the
    gerber files.  Generally you get "1 ounce" copper thickness (I think that
    is the weight of copper per square foot, but can be translated to a
    explicit thickness in um, mil, or whatever).  You pay more for thicker
    copper, like 2 ounce and 4 ounce.  4 ounce is pretty thick.  If you need
    more than that, you probably have to rethink what you're doing, use wider
    traces, run bus bars, etc.
    Important to note also is that the copper thickness is specified on a
    per-layer basis.  That is, each layer must be of uniform thickness.  You
    can not have particular traces thicker than others on the same layer.
    I have had several instances where I needed a high current trace (single
    impulse of 300+ amps) but could not afford the area that it would
    occupy.  To accommodate this, I place a wire on the mask layer that was
    directly above the copper layer, and later coated the copper trace with
    solder.
    Hope this helps.
    Enjoy,
        - Chuck
