Is there any way to print a selection from the 5.0 PCB Editor?
I have a small PCB surrounded by lots of fabrication drawing
text and would like to be able to print just the PCB portion
(e.g. for an assembly drawing or to print and check a layer).
forget the ideea
copy-paste the region of interest in a new board and print-it from there
"David Albert" <david_albert@axiometric.com> wrote in message
news:g3qfob$p3k$1@cheetah.cadsoft.de...
Usually for assembly drawings I only enable the t/bPlace, t/bNames,
t/bValues, and Dimension layers, then print. That's generally sufficient
to get a nice and clean assembly drawing with part outlines and such.
Eric Agan
http://www.elegantinvention.com
but the printed area contain and the invisible elements. this make
impossible printing only the visible layers centred on page (for example)
"Eric Agan" <eric@elegantinvention.com> wrote in message
news:g3rg7o$mmb$1@cheetah.cadsoft.de...
Eric Agan
Hello Eric Agan !:
Workaround - generate pdf file and then selsct area to print ....
Unfortunately no other sensible method
HTH
Grzegorz Zalot
complex ltd.
office tel/fax : +48 32 2505840
mobil : +48 501 301515
