EAGLE User Support (English) Help creating library
  • Subscribers 183 subscribers
  • Views 489 views
I need to create this land pattern from the figure attached, but I couldn´t.
Has anyone seen this land pattern? It is from a demodulator.
thanks
Thiago
    Thiago wrote:
    thanks
    Thiago
    Could you be more specific, what do you mean by you couldn't?
    Eric Agan
    http://www.elegantinvention.com
    "Eric Agan" <eric@elegantinvention.com> escreveu na mensagem
    news:g3u4vd$473$1@cheetah.cadsoft.de...
    Thiago wrote:
    couldn´t. Has anyone seen this land pattern? It is from a demodulator.
    thanks
    Thiago
    Eric Agan
    Well, I think it is missing some measures.... I don´t have too much
    experience with land pattern creation... I know the basics... Is there any
    adjustments that I could do to make this design easier?
    Thiago wrote:
    thanks
    Thiago
    Eric Agan
    Looks like you would have four pads of size 1.7x1.3 at each corner.
    EAGLE places pads on center, but this diagram shows their locations at
    the edges, so just do a bit of math: We know that from the bottom edge
    of the pad to the center is 3.3 (half of the 6.6 from pad-to-pad that is
    shown on the package diagram). Add half the height of the pad, so 1.7/2
    = 0.85, and you get 0.85 + 3.3 = 4.15, so that's our Y coordinate for
    the corner pads (and -4.15 for the bottom ones, of course). The X
    coordinate can be had in the same fashion: the diagram shows 9.4 from
    inner edge to inner edge, just like before. So it's 9.4 / 2 = 4.7 from
    the edge of one to the center, and again add half the length so 4.7 +
    (1.3 / 2) = 5.35, so the X coordinate is 5.35 image So your corner pads get
    placed at (5.35 4.15), (5.35, -4.15), (-5.35, 4.15), and (-5.35, -4.15).
    As for the other pads, they're 0.6x1.5 it looks like, and they're at
    1.0mm pitch. So we know they're 1.0 apart, and we have their size, only
    thing left is how far each row/column is from the center. The diagram
    shows that the two rows (top and bottom) are 8.8 away at the inner
    edges, so we know the inner is 4.4 from the center. Just like before we
    add half the length of the pad and we get 4.4 + (1.5/2) = 5.15 for our Y
    coordinate (and -5.15 for the bottom row). So, simply place them at (0,
    5.15), (1, 5.15), (2, 5.15), ... etc.
    The columns are spaced 9.0 apart (inner edge to inner edge), so same
    things goes (9.0/2) + (1.5/2) = 5.25 for the X coordinate, and we
    increment Y by 1 each time (remember, 1mm pitch). Place those at (5.25,
    0), (5.25, 1), etc...
    Hope that explains it,
    Eric Agan
    news:g3u6rj$9pl$1@cheetah.cadsoft.de...
    Thiago wrote:
    thanks
    Thiago
    Eric Agan
    any
    Looks like you would have four pads of size 1.7x1.3 at each corner. EAGLE
    places pads on center, but this diagram shows their locations at the
    edges, so just do a bit of math: We know that from the bottom edge of the
    pad to the center is 3.3 (half of the 6.6 from pad-to-pad that is shown on
    the package diagram). Add half the height of the pad, so 1.7/2 = 0.85, and
    you get 0.85 + 3.3 = 4.15, so that's our Y coordinate for the corner pads
    (and -4.15 for the bottom ones, of course). The X coordinate can be had in
    the same fashion: the diagram shows 9.4 from inner edge to inner edge,
    just like before. So it's 9.4 / 2 = 4.7 from the edge of one to the
    center, and again add half the length so 4.7 + (1.3 / 2) = 5.35, so the X
    coordinate is 5.35 image So your corner pads get placed at (5.35 4.15),
    As for the other pads, they're 0.6x1.5 it looks like, and they're at 1.0mm
    pitch. So we know they're 1.0 apart, and we have their size, only thing
    left is how far each row/column is from the center. The diagram shows that
    the two rows (top and bottom) are 8.8 away at the inner edges, so we know
    the inner is 4.4 from the center. Just like before we add half the length
    of the pad and we get 4.4 + (1.5/2) = 5.15 for our Y coordinate (and -5.15
    for the bottom row). So, simply place them at (0, 5.15), (1, 5.15), (2,
    5.15), ... etc.
    Eric Agan
    Ok Eric, thanks. I was kind of hoping to avoid all this by just doing the
    correct adjustments on the grid, maybe.
    Anyway, I´ll do the job by entering coordinates.
    Thiago
