    • Avnet Boards Community
EAGLE User Support (English) Can't add components (the component list empty)
  • Subscribers 174 subscribers
  • Views 786 views
For some reason, when I'm trying to add a new component to a schematic, using the ADD function, the component list is empty, as shown in the attached screen shot. Searching for a component doesn't work either. It's as if the dialog box is dead. The library seems to exist just fine, and I can even drag and drop components from the control panel window. What could be wrong?
I'm using Mac OS X 10.6.6 and I just updated to Eagle 5.11 (the latest version as of posting this) to see if that would solve the problem, which it obviously didn't since I'm posting this.
    0 Former Member over 14 years ago
    JFYI: There is no "attached screen shot". That incapable forum software
    obviously doesn't forward it to the newsgroup.
    wrong?
    HELP USE should solve your problem.
    Tilmann
    In the Control Panel window if you right-click the library name you can
    see that there is an option "Use All". If a library is used you will see
    a "green ball" after its name.
    -TeroK
    0 Former Member over 14 years ago in reply to Former Member
    Tero, that's it.
