EAGLE User Support (English) Same name pads and polygon oddness
  • Subscribers 178 subscribers
  • Views 235 views
I have two pads on a single part with the same net, pads 1 and 64 in the image.
Notice how pad 1 connects to the polygon versus pad 64? Why won't this connect
at all three points of pad 64?
BTW, I have not routed the signal going to pad 64 - its only the polygon.
Eric S.
  • Richard_H
    Richard_H over 17 years ago
    image. Notice how pad 1 connects to the polygon versus pad 64? Why won't
    this connect at all three points of pad 64?
    Eric S.
    Maybe the clearance value is too big, so the polygon can't connect
    to the smd. Please try to use either a bit finer width for the polygon
    or check and reduce the clearance value for wire/smd.
    Richard Hammerl
    autodeskguest over 17 years ago in reply to Richard_H
    the image. Notice how pad 1 connects to the polygon versus pad 64? Why
    won't this connect at all three points of pad 64?
    Eric S.
    Going to a finer width for the polygon worked. Thanks Richard.
