EAGLE User Support (English) How do I disable the Autorouter?
  • Views 630 views
  • eagle
  • pcb
  • autoroute
  • question
gbulmeruk
gbulmeruk over 15 years ago
I am using the free version of Eagle to design a small dense board.
I am hand-routing the PCB, and using the DRC check frequently to check clearances.
I've twice accidentally hit the 'Auto'-route button in the last couple of hours.
The autorouter creates a mess, and so I waste time unpicking the tracks it makes.
I'd like to keep my workflow smooth and streamlined, so I'd prefer not to have to explicitly do a save every time I am about to click DRC.
How do I disable the autorouter? I'd like to disable the autorouter forever unless I explicitly enable it (e.g. a global preference), or disable for the project.
PS - Undo after autoroute would be a very useful feature.
    0 e14 Contributor over 15 years ago
    So how do I disable the autorouter? I'd like to disable the autorouter forever unless I explicitly enable it (e.g. a global preference), or disable for the project.
    As a workaround, when you want to do a DRC do it from the command line.
      That's a good distance away from the autorouter, and 'drc' is a lot
    different from 'auto'.
    Tim Wescott
    Wescott Design Services
    Voice: 503-631-7815
    Cell:  503-349-8432
    http://www.wescottdesign.com
