EAGLE User Support (English) 1.27MM Hole Spacing
  • Subscribers 189 subscribers
  • Views 1566 views
1.27MM Hole Spacing
I'm trying to create a new device (with a new package) that is a simple 25
pin header. The pin spacing, however, is 1.27MM with a 0.75MM diameter pin.
When creating holes of 0.75MM in diameter spaced 1.27MM apart, I'm able to
size the pads the way I want to, without them touching each other (more that
0.005" of spacing, 0.127MM) . However, when I go to the device view with an
image of the package, it shows the pads are now touching each other, which
means all the pins are shorted together.
Is there something I'm missing, maybe a setting for a min diameter for a
pad?
Thanks for any help,
Nick.
    Klaus Schmidinger wrote:
    On 07/14/08 11:03, David Moodie wrote:
    It is the wonders of eagle's screwed up DRC
    Once more eagle should NEVER change anything the designer does without
    first asking if this is acceptable.
    Please get this sorted- check my design DO NOT CHANGE IT without
    asking me.
    The minimum restring requirement is something the board manufacturer
    will tell you. If, at any place, your board violates this requirement,
    this will typically cause the board manufacturer to get back to you
    and tell you that this board can't be manufactured at all, or needs
    to use a different manufacturing process, where the increased level
    of precision can be achieved.
    Yes... the board house runs a real design rule check
    Then they warn you of any failures
    Then after you explicitly approve the design they will go ahead.
    You still want to know how many and what marginal issues exist but you do
    not want them changed without approval.  So check is good change (without
    approval) is bad.
    cheers
    David
    that's not true in any case.
    I can use some vias with smaller "restring" (or no "restring" at
    all) without any problem, and I want to be able to do so.
    But I want to be warned about this, and currently Eagle has no
    design rule check for minimum "restring". That's a severe drawback
    since version 4.
    After all, check and change must be separated nevertheless.
    Greetings,
    Oliver
  • kcadsoft
    kcadsoft over 18 years ago
    Please get this sorted- check my design DO NOT CHANGE IT without asking me.
    If you don't want EAGLE to assure the minimum restring requirement
    automatically, you can set this parameter to 0 in the design rules.
    It will then use exactly the diameters you have set in your libraries.
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
    Nick wrote:
    pad?
    Nick.
    You design a package which is marginal with respect to annular ring, but you
    are prepared to make an exception for this part,say. BUT eagle applies its
    the global DRC setting - thinks it knows better than you and makes all the
    pads bigger as the one you set explicitly violates its own idea of what your
    annular ring (restring) parameters should be.
    Strangely enough this then violates the min pad to pad clearance, but that
    would apparently be applied after the restring parameter - Its a genuine
    check rather than the resting parameter which is a ch
    Once more eagle should NEVER change anything the designer does without first
    The solution is to reduce your global restring parameters- NOTE that this
    parameters is not something that is simply checked but a global design rule
    change.    In you case you will need to reduce the min restring for pads
    to less than 0.1mm - this is not good for production but you could also use
    elongated pads to improve things.
    I really like Eagle, but I absolutely loathe this aspect of the DRC.  Please
    cheers
    David
    e14 Contributor over 18 years ago
    You've got to adjust the 'Restring' settings in the DRC options. Reduce
    the Min and % values to avoid overlapping pads. Be careful not to exceed
    the restrictions of your PCB-house.
    Markus
    Help DRC, here are global settings
    r
