EAGLE User Support (English) Making cut-out in filled polygon
  • Replies 8 replies
  • Subscribers 180 subscribers
  • Views 4381 views
  • cutout
  • eagle
  • polygon
Hi all.
  I'm trying to make cut-out zone in filled polygon. I'd like just to define a zone in the polygon, which will have no fill.
In KiCad this function is named - "Cutout area" (Zones->Add cutout area).
Is there a way to do this in Eagle?
Michev
    0 Former Member over 14 years ago
    On 7/6/2011 2:20 PM, michev wrote:
    Hi all.
    Michev
    On the outer layers you can create a polygon in trestrict or brestrict.
    On other layers you can create a polygon with a different net name with
    a higher rank.
    michev wrote:
    Hi all.
    define a zone in the polygon, which will have no fill. In KiCad this
    Assuming you are talking of  a signal polygon on the top or bottom layer
    For  a polygon on layer 'Top', cut out a shape by placing the cutout shape
    on layer ' tRestrict'
    For  a polygon on layer 'Bottom',cut out a shape by placing the cutout shape
    on layer 'bRestrict'
    Warren
    0 Former Member over 14 years ago in reply to Former Member
    Thanks for the fast answer.
      Unfortunately this was the first thing that I try.
    The result is - polygon in tRestrict is created and filled, but does not  prevent filling of this area by my GND polygon on top layer.
    Michev
    Edit: Solved! image
    For some reason, ratsnest was not working correctly after I put restrict polygon. Restarting Eagle and executing a "SET POLYGON_RATSNEST ON;" command, everything went just fine.
    Thanks!
    Michev
    Your image did not make it to nntp.
    Is it possible that you used a rectangle rather than a polygon?
    >>   Image:Screenshot-6.png
    >> Michev
    Doug
    Michev posted at Element14. Attachments there don't get sent to nntp
    He also found his problem and edited his initial post with an update and
    those don't get to nntp either.
    I have my nntp messages automatically coloured blue when they come from
    Farnell so that I can tell its an Element14 message.
    Warren
  • Richard_H
    0 Richard_H over 14 years ago in reply to Former Member
    Am 06.07.2011 23:59, schrieb Warren Brayshaw:
    michev wrote:
    >> Hi all.
    Warren
    In addition you can try the following for inner layers:
    Draw a polygon that has the same shape as the restricted area and
    set its Rank = 1. All other polygons in this layer must have a higher
    rank (for example 2). Thus all other polygons have to respect the
    "restrict" polygon. Check the name of the polygon and draw a small
    wire with the same name anywhere outside the polygon (it must not be
    reachable for the poylgon). If the polygon has set the property
    Orphans = Off, it can't be calculated and the area remains free.
    Although the contour of the polygon is shown in the layout editor, it
    is no problem at all for data output with the CAM processor. The
    outline wires of the polygon do not appear in the manufacturing data.
    Richard Hammerl
    >>> Michev
    Doug
    Warren
    Warren,
    Good to know.
    Doug
    warrenbrayshaw wrote on Wed, 06 July 2011 22:31
    and
    from
    Good point Warren.  I just changed http://www.eaglecentral.ca/forums so
    that users can't edit posts--not even their own.  Users are now forced to
    reply to their own message and make the edits.  This way, nntp and
    eaglecentral forum users will all see the same info.
    Not ideal, but it's worth the extra hassle to keep things in sync.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
