Hi, Sir,
Just upgrade 4.16r2 to 5.1.0.
In a tiny project, I found CAM utility cannot generate tStop layer properly.
Here attached the board for your reference.
C.Y. Chen
Hi, Sir,
C.Y. Chen
On 07/17/08 09:59, Cadsoft news wrote:
Hi, Sir,
Fixed for version 5.1.2 (see news://news.cadsoft.de/eagle.betatest,
wjere we will announce when the next beta version will become available).
As a quick workaround you can either comment out the lines
AreaBegin = "G36*\n"
AreaEnd = "G37*\n"
from your eagle.def file (which turns off drawing rotated rectangles
as polygons), or make sure there is at least one other object in
the respective layer that doesn't result in a rotated rectangle.
The problem only happens if there are no other objects than rotated
rectangles.
Klaus Schmidinger
Klaus Schmidinger Phone: +49-8635-6989-10
CadSoft Computer GmbH Fax: +49-8635-6989-40
Hofmark 2 Email: kls@cadsoft.de
D-84568 Pleiskirchen, Germany URL: www.cadsoft.de
