EAGLE User Support (English) Creating a gap in a ground plane
  • Subscribers 180 subscribers
  • Views 267 views
I have a part on a four layer board which needs to have no ferrous material under it. Currently, all four layers have a fill of some sort. What I'd like to do is draw a sort of "negative" polygon surrounding the part so that the ground/power planes will stop at the part. Is this possible?
Michael
    0 Former Member over 14 years ago
    There aren't any inner layer restriction layers in Eagle.  You will have to trim a polygon to fit your needs.  If you already have it in place you can use the split command to redefine parts of the edge.
