EAGLE User Support (English) Embed Colour Palette into Board File
  • Replies 7 replies
  • Subscribers 179 subscribers
  • Views 559 views
For EAGLE to become more accepted into the professional ranks, it is
important that it is easy to share EAGLE files from customer to design
house.  One thing that is really frustrating is that the colour palette is
not stored in the board file.  So if I use a custom colour palette (i.e. The
colours above index 16) when my customer gets them it just looks black (or
maybe all grey with the new defaults in EAGLE 5, haven't check if that was
implemented as discussed).
Why not just simply treat the colour palette like any other setting that
goes through the GUI.  For example, the DRC settings are set and stored in
the PCB.  You use the local copy until you load/change a new set using the
GUI.  Please treat the colour palette the same.
This has always been a required feature, but now with EAGLE 5 even more so.
I don't like the colour palette that is by default, I need to change it to
work efficiently.  Also, my boards are often more than 6 layers so I need
the colour differences to be more subtle to allow for more layers.
So please, please, incorporate this as soon as possible.
Cheers,
James.
~  James Morrison  ~~~  Stratford Digital  ~
~  email:  sales@eagletoolkit.com          ~
~  fax:    888.701.8097                    ~
~  web:    http://www.eagletoolkit.com     ~
~  Online EAGLE Dealer for US and Canada   ~
~  EAGLE Design Experts                    ~
~  EAGLE Enterprise Toolkit                ~
  • esilviu
    esilviu over 17 years ago
    +1
    until it's solved, I consider this a bug!
    "James Morrison" <spam2@stratforddigital.ca> wrote in message
    news:C4A8CB2B.69C83%spam2@stratforddigital.ca...
    The
    so.
    Cheers,
    James.
  • kcadsoft
    kcadsoft over 17 years ago
    On 07/20/08 16:59, James Morrison wrote:
    There are three color palettes, for black, white and colored background,
    respectively. The palette for a particular type of background is used
    in both board and schematic context.
    If we store the palettes in the drawing file, how should they be treated
    whe a user loads a file from somebody else? If the other user only cared
    about the black palette, but this user uses the white palette, there would
    still be no colors defined.
    Besides, the layer colors are more like a personal setting. One user
    might consider the Top layer to be red ("of course it's red, it's always
    been red"), while the other one can't tell red from green and thus uses
    yellow as his top layer color ("of course it's yellow, it's always been
    yellow"). From this point of view we are actually already storing
    too much information in the drawing files - the color palette index
    should never have gone in there to begin with!
    When we get drawing files from our users in order to reproduce some
    problem, the color indexes are often set to "exotic" values, so
    the first thing we do is to run our own "set color" script in order
    to be able to actually "see" what's in the drawing.
    Maybe all it takes is to fill the default color palettes with actual
    values (not just grey). So if you (or anybody else here) could come
    up with a reasonable suggestion for the default colors (in all three
    palettes), we might consider adopting them.
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
  • esilviu
    maybe the color pallete is useles....
    all default layers can have implicit colors, user can change any of that
    (the "choose color" dialog will become "set colors" - for both (highlighted
    and usual color)), and colors for used layers can be stored in sch and brd
    files.
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
    news:g64gar$h07$1@cheetah.cadsoft.de...
    is
    The
    (or
    was
    in
    the
    so.
    to
    Klaus Schmidinger
    I agree that color profiles are personal info, no real need to put them
    in files.
    Every user seems to have a preference.
  • esilviu
    I use a different pallete for every project...
    "Gary Gofstein" <ggofstein@lbl_nospam.gov> wrote in message
    news:g65ctp$i54$1@cheetah.cadsoft.de...
    I agree that color profiles are personal info, no real need to put them in
    files.
    Hello eSilviu !:
    Why ?????
    regards
    Grzegorz Zalot
    complex ltd.
    office tel/fax : +48 32 2505840
    mobil : +48 501 301515
    http://www.complex.org.pl/
  • esilviu
    because I get bored....
    "Grzegorz Zalot" <complex@alpha.pl> wrote in message
    news:g66ldg$e67$1@cheetah.cadsoft.de...
    Hello eSilviu !:
    Why ?????
    regards
    Grzegorz Zalot
    complex ltd.
