EAGLE User Support (English) Split Symbol Across Multiple Pages
  • Subscribers 189 subscribers
  • Views 1442 views
  • eagle
  • library
  • split
  • schematic
  • symbol
Hello.
I have a device with several hundred pins.  For the sake of organizing my schematic, I'd like to split the library symbol across two pages---I can't easily fit it on to a single page at the moment.  Is this possible in EagleCAD?
Any hints or ideas on how to do this (or just make the symbol more manageable) are most appreciated.
    0 autodeskguest over 10 years ago in reply to kingsthegreat
    Am 26.04.2016 um 12:09 schrieb Ulemu phiri:
    Hey man, I kind of have the same problem with my device in eagle. Could
    you please explain in simple way how you managed to solve the problem
    above?
    https://www.element14.com/community/message/195636
    The device has to consists of several symbols which you add into
    the device editor. There you can choose between several Addlevels.
    Please take look into the manual about library definition for details.
    If the Device is defined this way, you can ADD gate by gate into the
    schematic. To place a not yet placed gate on another schematic sheet use
    the INVOKE command and type the name of the component in the
    command line. Now a selection menu appears.
    HTH
    Richard Hammerl
    above?
    HTH
    Richard Hammerl
  • kingsthegreat
    0 kingsthegreat over 10 years ago in reply to e14 Contributor
    Hey man, I kind of have the same problem with my device in eagle. Could you please explain in simple way how you managed to solve the problem above?
    0 e14 Contributor over 15 years ago in reply to e14 Contributor
    Thanks---that works like a charm image
    On 09/18/2011 04:03 PM, Ash Charles wrote:
    Hello.
    On complex IC's, such as microcontrollers, I split the symbols into
    logical blocks.  GPIO A, GPIO B, Power block, JTAG block, USB, EBI, etc.
    for this very purpose.  The only symbol in the device that is marked
    MUST is the power block.  Everything else is marked as CAN.  IN then use
    INVOKE to place the CAN blocks on separate sheets.
    DPDT relays are treated the same way.  ADD places the coil, and INVOKE
    places each pole.
    Enjoy,
        - Chuck
