EAGLE User Support (English) USB routing problems : D+/- length issues
  • Replies 30 replies
  • Answers 2 answers
  • Subscribers 191 subscribers
  • Views 3518 views
  • length
  • d-
  • autorouter
  • usb
  • parallelism
  • d+
Hello everyone
I'm a user of Eagle for 2 years now, and i'm trying to make USB with an Overo and a dsPIC.
The thing is that I had read somewhere (http://www.usb.org/developers/docs/hs_usb_pdg_r1_0.pdf) that the signals D+ and D- must have the same length (they talk about non parallelism page 10 figure 5)
But here is the point : how you do that on Eagle , to force 2 wire to have the same length (or being parallel all the way), in autorouter mode of course but even in manual mode.
Thanks for the help .
Best Regards
  • kcadsoft
    0 kcadsoft over 14 years ago in reply to e14 Contributor
    On 09/26/11 14:02, Christian Bohrer wrote:
    "Klaus Schmidinger"<Klaus.Schmidinger@cadsoft.de>  a écrit dans le message de news:
    >> We mainly need the information which signals form a differential
    >> pair in the board - and there all we have is the name and net
    >> class.
    And why not an ATTRIBUTE for nets? Visible or not in schematic...
    ATTRIBUTEs are only available for parts/elements, not for
    nets/signals.
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    0 e14 Contributor over 14 years ago in reply to kcadsoft
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> a écrit dans le message de news:
    j5plqa$ve5$1@cheetah.cadsoft.de...
    On 09/26/11 12:06, Morten Leikvoll wrote:
    >> "Klaus Schmidinger"<Klaus.Schmidinger@cadsoft.de>  wrote in message
    >> news:j5ibr9$cn7$1@cheetah.cadsoft.de...
    >>> There has to be some way of identifying which two signals form
    >>> a differential pair, and that's going to be via the signal names.
    >>> We can discuss which way this is done, so if '+' and '-' appear
    >>> inappropriate, we could use "_P" and "_N".
    >> If the name matching is the best way, I suggest supporting these user
    >> parameters:
    >> -matchstring
    >> -match location (first,end,anywhere)
    >> or simply a single matchstring with room for wildcard in front or/and at
    >> tail.
    >> Examples:
    >> matchstring="(n/p)_*" for (n_clk,p_clk)
    >> matchstring="*(/-)" for (clk,clk-)
    >> matchstring="(+/-)" for (data0,data-0,data1,data-1,..,data+7,data-7)
    >> (ps:not using proper regexp here, just pseudo where * is a wildcard of
    >> unknown length)
    See my reply to Johann Glaser.
    >> I think support for these are needed, but I sense a high level of potential
    >> support cases. Maybe because you may want a mix of all these and can easily
    >> use wrong names.
    >> I would think a link to the complementary net would be much nicer. It could
    >> have been done with a new command so that ULP's can handle it in your
    >> preferred way.
    >> An alternative would be to handle a diff pair as a special 2 wire 'bus' at
    >> sch level, but I dont think the current bus implementation is suitable for
    >> that.
    class.
  • kcadsoft
    On 09/23/11 15:49, James Morrison wrote:
    Klaus Schmidinger wrote on Fri, 23 September 2011 03:46
    >> This can't guarantee the same length for both signals, so there
    >> will also be a new command that generates "meanders" to compensate
    >> for length differences, or to create a fixed total length of a
    >> differential pair.
    Klaus, will this new command that adds "meanders" be able to take a list of
    signals, not just a diff pair?  If so, it could be used to equalize trace
    lengths across a bus like DDR, DDR2,  etc.
    We'll try to make that work.
    Klaus Schmidinger
  • kcadsoft
    parameters:
    -matchstring
    tail.
    Examples:
    unknown length)
    use wrong names.
    preferred way.
    that.
    class.
    Klaus Schmidinger
  • kcadsoft
    0 kcadsoft over 14 years ago in reply to Johann.Glaser@gmx.at
    On 09/24/11 11:46, Johann Glaser wrote:
    Hi!
    Am Freitag, den 23.09.2011, 18:24 +0200 schrieb Klaus Schmidinger:
    >>> news:j5hdh5$va6$1@cheetah.cadsoft.de...
    >>>> In V6 the (manual) ROUTE command will treat signals that have the
    >>>> same net class and the same name (one ending with '+' and the other
    >>>> with '-') as "differential pairs". When picking up one airwire of such
    >>>> a pair, both signals will be routed in parallel, keeping the distance
    >>>> as defined in the net class.
    >>> You should be a bit careful about using the + and - signs. It works as long
    >>> as you dont export netfiles to other tools, but + and - in names are often a
    >>> source of confusion and problems. As an example, we export netnames
    >>> connected to FPGA's and feed them into the pin assignment files. That tool
    >>> will not allow + and - and simply replacing it with something else is a
    >>> potential source of conflict.
    >> We could just as well use something more exotic, like "_P" and "_N".
    I second the thoughts on the '+' and '-' chars in names.
    As you have written, you don't like to add another kind of a setting to
    specify which signals belong together, we might only have the naming.
    What do you think of making the naming configurable? The default could
    be:
      - '_n' / '_p'
    (both, but only within its little groups). But this should be possible
    to change with a dialog or "set" command. If somebody wants signals with
    that name ending, but not have them routed together, just remove the
    setting for that schematic/board. If somebody wants special name endings
    for differential pairs, e.g. '_PLUS' and '_MINUS', he simply sets it
    accordingly.
    So it would be nice to have zero to "a few" pair name ends to be setup.
    This would mean the selection would have to be stored in the schematic/board,
    and thus would make combining two files from different sources
    ("design reuse") virtually impossibe.
    A fixed convention avoids such problems altogether.
    Klaus Schmidinger
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
    parameters:
    -matchstring
    tail.
    Examples:
    unknown length)
    use wrong names.
    preferred way.
    that.
  • kcadsoft
    >> On 09/23/11 08:08, Tilmann Reh wrote:
    >>> In EAGLE, there is no way to /force/ an equally long differential pair
    >>> during routing, neither manually nor by autorouter. Maybe V6 will add
    >>> something new here, but I don't know.
    >> differential pair.
    When you say "manual ROUTE", is the follow-me router included?
    I'm afraid not. This is purely "manual".
    Klaus Schmidinger
    j5hmbi$571$1@cheetah.cadsoft.de...
    >> does that mean there will be more than 7 net classes?
    We were thinking about increasing this number to 16.
    Excellent idea!
    differential pair.
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Am 25.09.2011 14:07, schrieb James Morrison:
    Klaus Schmidinger wrote on Sat, 24 September 2011 05:04
    >>> And what about whole busses that should be routed together?
    >> The differential pair feature we are currently implementing is
    >> only about two signals being routed in parallel.
    I think this is the crux of the debate here.  From what I've read (and
    posted), many of us are trying to extend this tool to match length across
    signals on a bus.  Also, there appears to be two tools that Klaus is
    discussing:  differential pair routing and automatic length matching.  As
    we haven't see the beta none of us outsiders have seen how this is
    implemented and how tightly the two tools are tied together.
    So I would say, that even though you aren't intending to allow length
    matching across a bus you should allow a way to specify signals in a diff
    pair that is scalable to an entire bus.  This way you could (and should)
    expand the function in the future.
    This way, it will also make sure they don't get implemented in such a way
    as it won't be extendable in the future.  The diff pair routing tool and
    the bus length matching tool should be independent tools, in my opinion.
    With these criteria in mind, I don't think identifying them via signal name
    makes sense.
    I would prefer to make this a bus property and say that diff pairs need to
    defined as their own bus.  You can unlimited number of busses (unlike net
    classes).  This also expands nicely to trace length matching across a bus.
    Maybe you have a bus flag called "differential" that you set to trigger the
    diff pair routing.
    Also note, I don't want the tool to just start routing things it thinks
    are differential.  I should have to explicitly tell it that the two signals
    are differential. This bus methodology above respects that.
    Cheers,
    James.
    Fully agreed James. Even if Klaus implements a diff-pair "only" now, it
    would benefit in future.
    Joern Paschedag
