EAGLE User Support (English) Not a valid Win32 Application
  • Replies 7 replies
  • Subscribers 189 subscribers
  • Views 727 views
jaybeckham
jaybeckham over 14 years ago
I get this message when trying to install Eagle 5.11.0 on a Windows XP computer
    0 e14 Contributor over 14 years ago in reply to jaybeckham
    Jay Beckham <communitymanager@premierfarnell.com> wrote:
    Yes, that is the file and it came from Cadsoft
    Try downloading it again.
    Maybe there have been å problem with the link the minute you downloaded it?
    The extracted file looks like the Mac version.
    If that doesnt work, please post the full download link you use.
  • jaybeckham
    0 jaybeckham over 14 years ago in reply to e14 Contributor
    On 09/29/2011 04:13 PM, Jay Beckham wrote:
    Archive.pax.gz is the only  large file in the folder.  How do I open that in Windows XP?
    ftp://ftp.cadsoft.de/eagle/program/5.11/eagle-win-5.11.0.exe
    Is this the file you started with? or where did you get the file from?
    It seems you may have downloaded a version for a different OS.
    Paul
  • jaybeckham
    0 jaybeckham over 14 years ago in reply to jaybeckham
  • jaybeckham
    I downloaded and unziped into a folder Eagle on the Desktop.
    I did not see any install or setup files or even an exe file.
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Tilmann Reh wrote:
    >> XP computer
    I don't know if that's a problem of the current installer exe file or
    of your system - but you can easily install EAGLE without using the
    installer itself. Simply rename the file to .zip and then unpack the
    contents to your desired target directory. At least you can use it
    then, even if the current installer maybe broken.
    Tilmann
    P.S. When posting screenshots, do not use JPEG format - instead use
    PNG or GIF (eventually with reduced colors), the files are much
    smaller and lack those compression artefacts.
    I note that this is an Element14 post with an attachment. Looks as if
    repairs are being made.
    news.cadsoft.de
    I don't know if that's a problem of the current installer exe file or of
    contents to your desired target directory. At least you can use it then,
    Tilmann
    PNG or GIF (eventually with reduced colors), the files are much smaller
