EAGLE User Support (English) EAGLEDIR
  • Subscribers 178 subscribers
  • Views 992 views
EAGLEDIR
Phil_Keller
Phil_Keller over 17 years ago
I have just upgraded to Eagle 5.0 and then upgraded to 5.1.  I have a
Non-profit Standard License.  When I start the 5.x program the library
is pointed to by the variable $EAGLEDIR that is currently set to my 4.16
libraries.  I am not ready to remove 4.16 as some of the designs are
still there and I have not yet made the transition fully to 5.
   Where is the value of EAGLEDIR set and how can I change it to point
to the 5.0 structure?
Phil
    Just type the entire path to where it's located, for instance:
    d:\cad\eagle5.1\projects
    d:\cad\eagle5.1\lbr
    Etc.. etc...
    "Phil" <Phil@PKeller.net> wrote in message news:g63irt$tb2$1@cheetah.cadsoft.de...
    I have just upgraded to Eagle 5.0 and then upgraded to 5.1.  I have a Non-profit Standard License.  When I start the 5.x program
    the library is pointed to by the variable $EAGLEDIR that is currently set to my 4.16 libraries.  I am not ready to remove 4.16 as
    some of the designs are still there and I have not yet made the transition fully to 5.
      Where is the value of EAGLEDIR set and how can I change it to point to the 5.0 structure?
    Phil
    That will work for each time I install the SW but the variable $EAGLEDIR
    is set someplace and has a value of the old structure.  I don't mind
    setting it for the 4.16 stuff but I would like to update it for the 5.x
    version.
    d:\cad\eagle5.1\lbr
    Etc.. etc...
    Phil
  • kcadsoft
    kcadsoft over 17 years ago
    the 5.0 structure?
    EAGLEDIR ist the directory that contains the version of EAGLE
    you are currently running.
    It is determined at runtime, by taking the full path name to
    the eagle.exe file and stripping the "\bin\eagle.exe" part.
    So if you have installed EAGLE into
       C:\Program files\EAGLE-5.1.0
    the EAGLEDIR variable will contain the value "C:\Program files\EAGLE-5.1.0".
    when you run "C:\Program files\EAGLE-5.1.0\bin\eagle.exe".
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
    Klaus,
       Well kind-of.  What I think I understand is the following.
       For some reason the "Library Use" list included all the libraries in
    the 4.16 structure.
       When I look at the libraries in the Library list in the Control Panel
    I see the libraries in 5.1.  If I open a schematic that was created in
    5.1 and click "add" the libraries are in the 4.16 structure (as shown by
    the path displayed and their contents).  Dropping them and then adding
    the 5.1 libraries seems to have solve the problem.
       It still seems strange to me that it pointed to the 4.16 but a
    solution is at hand.
       Danke,
    Phil
    4.16 libraries.  I am not ready to remove 4.16 as some of the designs
    files\EAGLE-5.1.0".
    Klaus Schmidinger
    Phil wrote:
    Klaus,
    the 4.16 structure.
    Panel I see the libraries in 5.1.  If I open a schematic that was
    created in 5.1 and click "add" the libraries are in the 4.16 structure (as
    shown
    by the path displayed and their contents).  Dropping them and then
    adding the 5.1 libraries seems to have solve the problem.
    I have experienced the same thing more than once when upgrading to a new
    version of Eagle.  And yet when I type "open somelib" in the schematic
    editor, it opens a library in the new Eagle directory.  That becomes very
    confusing when you create a new device in a library, then go to Add it to
    your schematic, and it's not there!  I also have solved the problem by
    dropping all libs and adding the correct ones.
    Bert Menkveld
      Danke,
    Phil
    a Non-profit Standard License.  When I start the 5.x program the
    set to my 4.16 libraries.  I am not ready to remove 4.16 as some of the
    fully to 5. Where is the value of EAGLEDIR set and how can I change it
    to
    files\EAGLE-5.1.0".
    Klaus Schmidinger
