EAGLE User Support (English) Rename vias in ULP
  • Replies 7 replies
  • Subscribers 189 subscribers
  • Views 1335 views
Rename vias in ULP
Hi
is it possible within a ULP to rename vias?
I have the following situation, I have an RF board with polygons on 3 layers and several hundred vias linking these together.  The polygons all have the same name but the vias all have  diffrent names, i do not like the prospect of going throuch the NAME gui close on a thousand times.
I have tried NAME S$11 g in the command line (where S$11 is the name of a via as shown by the name dialogue) - this returns "unknown element: S$11 "
  • kcadsoft
    0 kcadsoft over 14 years ago in reply to e14 Contributor
    On 10/04/11 15:44, Chuck Huber wrote:
    On 10/04/2011 03:18 AM, Klaus Schmidinger wrote:
    >> On 10/03/11 20:43, Chuck Huber wrote:
    >>> I might add that you can skip the units conversion if you just use the
    >>> finest grid.
    >>>             exitScript += "GRID FINEST;\n";
    >> That's not correct. "GRID FINEST" switches to the finest
    >> possible grid, which is 0.1 micron. So internal coordinate
    >> units need to be converted to "microns" when using them in
    >> EAGLE commands.
    Good morning, Klaus,
    I thought the internal coordinate units /were/ in 0.1 micron.  So if the
    grid was set to FINEST, the ULP could emit the VIA.x and VIA.y values to
    a script without conversion.
    >>              sprintf(cmdBuf, "name %s (%d %d);\n", "newNet",
    >>                  VIA.x, VIA.y);
    What am I missing?
    The internal representation of coordinates and sizes are integer
    numbers in multiples of 0.1 micron. So if you have an internal
    coordinate of, say, 1234 this means 123.4 micron. If you do
    GRID FINEST;
    NAME ... (1234, ...);
    you will address a point at an X coordinate of 1234 micron, which
    is ten times the actual value.
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    0 e14 Contributor over 14 years ago in reply to kcadsoft
    >> finest grid.
    EAGLE commands.
                    VIA.x, VIA.y);
    What am I missing?
        - Chuck
  • kcadsoft
    finest grid.
    EAGLE commands.
    Klaus Schmidinger
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    that is a bit contradictory. If the vias all have different names,
    they are most likely not linked to any signal and therefore not
    connected to any of your polygons.
    But that is probably the reason you want to change the names of the
    vias 8-)
    you should have used the "via 'signal name' ..." variant of the via
    command when you placed the vias in the first place.
    for changing the names after the fact you will have to resort to the
    methode Chuck already described.
    You could do this:
    Find the netnames used in the scematics, group any via that has a name not
    in this entity and rename them. This is esy to do in an ulp, but unless
    your board is huge or you need some ulp exercise I would just rename each
    one.
    vias 8-)
    Lorenz
    On 10/03/2011 09:00 AM, Chuck Huber wrote:
    On 10/03/2011 08:10 AM, Stephen Cole wrote:
    >> Hi
    Have you tried grouping the vias and do a change name on the group?
    Unfortunately you can not identify a via by it's name, since the name
    reflects the name of its host net.
    But, vias can be identified by coordinates.
    You can't change anything in a ULP since they are read-only, but a ULP
    can create a script that can be executed on exit from the ULP.  The
    script needs to be of the form:
        name newNet (x y);
    where "newNet" is the name of the polygon to which the via should
    connect, and "x" and "y" are the coordinates of the via.  In the ULP you
    can:
    The next challenge is to spin through all the signals looking for vias
    that need their name changed.  You can use a structure similar to:
    string cmdBuf;
    string exitScript;
    board(B) {
            // Set the grid to mils
            exitScript += "GRID mil;\n";
    finest grid.
            // Spin through the board's signals
            B.signals(SIG) {
                // filter out signals that we do NOT want to examine
                if (strcmp(SIG.name, "unwanted"))
                    continue;
                // Spin through each via on this signal.
                SIG.vias(VIA) {
                   // do other tests to eliminate vias that don't need
                   // changing
                   // collect vias to change
                   sprintf(cmdBuf, "name %s (%f %f);\n", "newNet",
                         VIA.x, VIA.y);
                   exitScript += cmdBuf;
                } // End of vias loop
            } // end of signals loop
            // Set the grid back to what it was.
            exitScript += "GRID last;\n";
    }  // end of board
    // Execute the script we just built.
    exit(exitScript);
    Enjoy,
        - Chuck
    Hi
        name newNet (x y);
    can:
    string cmdBuf;
    string exitScript;
    board(B) {
            B.signals(SIG) {
                    continue;
                SIG.vias(VIA) {
                   // changing
                u2mil(VIA.x), u2mil(VIA.y));
    }  // end of board
    exit(exitScript);
    Remember that the X and Y coordinates of the via are expressed in native
    units, and need to be converted to whatever your grid unit is set to
    before appending the script command to the exit string.  See the
    u2mil(), u2mm(), and u2inch() functions on page 92 of the ULP manual,
    ulp5110_en.pdf.
    Hope this helps.
    Enjoy,
        - Chuck
