Is it possible to modify an SMT pad to look like the one attached? If so,
how is that done?
how is that done?
Someone please answer...
"Charlie Van Dien" <vandien@bellsouth.net> wrote in message
news:g6cvuu$5gt$1@cheetah.cadsoft.de...
how is that done?
how is that done?
Your picture just shows a plain rectangular pad. You can make such pads
easily. In the package editor of the library place an SMD of any size
and then use the CHANGE SMD command to alter the size. When you type
that command you get a drop-down menu with the preset sizes listed, and
at the bottom, a line with three dots. Choose this and you are given a
window where you can insert the dimensions you require. Maximum value of
either x or y is 0.516024"
John G.
Thanks John,
Take a look at the pad again, it has (8) sides not (4).
-charlie
"John Giddy" <jgiddy@bigpond.net.au> wrote in message
news:g6gain$tsk$1@cheetah.cadsoft.de...
so, how is that done?
easily. In the package editor of the library place an SMD of any size and
then use the CHANGE SMD command to alter the size. When you type that
command you get a drop-down menu with the preset sizes listed, and at the
bottom, a line with three dots. Choose this and you are given a window
where you can insert the dimensions you require. Maximum value of either x
or y is 0.516024"
John G.
Thanks John,
-charlie
or y is 0.516024"
John G.
Sorry.
It looked more like a rectangle with a shaded edge in my picture viewer.
John G.
Thanks John,
-charlie
If so, how is that done?
pads easily. In the package editor of the library place an SMD of any
size and then use the CHANGE SMD command to alter the size. When you
type that command you get a drop-down menu with the preset sizes
listed, and at the bottom, a line with three dots. Choose this and
you are given a window where you can insert the dimensions you
require. Maximum value of either x or y is 0.516024"
John G.
Sorry.
John G.
If you are talking the black C shape that is not possible without DRC
errors in 4.1x. You could use 3 rectangular pads but DRC will flag it
with pad to pad distance error.
Named copper is not allowed in the lib parts. You can adjust the solder
stop mask to any shape and use a larger rectangular pad with no stop
active. Or make the correct shape stop mask and add a named polygon to
the board after placing the part.
Named Polygons in lib's is a frequently requested suggestion.
Paul R.
